Prince Tûrion Rilyalocë and the Golden Drake Laurëdrauginir
Re: Prince Tûrion Rilyalocë and the Golden Drake Laurëdrauginir
These are fantastic
- Turion Rilyaloce
Take a voyage to Tor Caled and behold Prince Tûrion Rilyalocë and the mighty Laurëdraugnir as well as their Caledorian host.http://www.ulthuan.net/forum/viewtopic.php?f=5&t=46899
- Turion Rilyaloce
Not High Elves, but related as a side project I am working on until my rank and file arrive.
Learning experience that should help some with High Elves.
Usually when I do a grisaille before inks, I stop in normal values with the Whites. Which means I end up painting them anyways after when I’m already most of the way there. Why am I doing this?
So for this model, I under coated it with Russ Grey, and then just brought the midtones up to like 85 percent opacity and the highlights all the way.
I think this white is pretty much done and it was the initial airbrush work. Might brush over with some really thin white just to smooth it out, but I’m going to try to apply this to my other models especially with their robes.
- Attachments
- FE6C155A-E31C-4AE2-BA64-4A03E6C5D80F.jpeg (1.27 MiB) Viewed 2920 times
- Turion Rilyaloce
They have finally crossed the Shining Sea. My Army is arrived.
- Attachments
- C683C78D-3A6C-4812-AB3B-CA880DBDF403.jpeg (1.04 MiB) Viewed 2893 times
- 85C0B20C-F346-4285-9201-5E6D9268A6E1.jpeg (1.07 MiB) Viewed 2893 times
- 484F4291-8EBE-4F26-AA93-67DCC68B02C9.jpeg (948.53 KiB) Viewed 2893 times
- Anduil of Elithis
Beautiful sculpts! Where are they from and did you already compare their size with your existing miniatures?
- Turion Rilyaloce
They are Elves of Silvermoor. The print shop lets you choose the scale, but they are slightly taller and thicker than normal High Elves.Anduil of Elithis wrote: ↑Sat Jul 27, 2024 7:53 pm Beautiful sculpts! Where are they from and did you already compare their size with your existing miniatures?
I’m chalking that up to Caledorian blood.
- Turion Rilyaloce
Did some light sketches and these should be fun. They look slightly more aggressive than normal HE, which suits my theme.
Plus look at those baller wingtip shoes!!
- Attachments
- E83FCB01-7400-4375-B705-0E5D08BF3A1A.jpeg (1.03 MiB) Viewed 2871 times
- DD3ABD79-793D-4970-8452-770F945353CD.jpeg (1018.73 KiB) Viewed 2871 times
- BBC9406C-6DAD-49AF-9E04-D901457DD647.jpeg (1.47 MiB) Viewed 2871 times
- Anduil of Elithis
Thanks, I will give them a look!Turion Rilyaloce wrote: ↑Sun Jul 28, 2024 1:27 amThey are Elves of Silvermoor. The print shop lets you choose the scale, but they are slightly taller and thicker than normal High Elves.Anduil of Elithis wrote: ↑Sat Jul 27, 2024 7:53 pm Beautiful sculpts! Where are they from and did you already compare their size with your existing miniatures?
- Turion Rilyaloce
Need some input. Should the plate armour be;
- more silver like the scales and a traditional High Elf scheme
- more gold like the trim, my host is Caledorian, my dragon is gold, and for some reason gold is faster for me.
- Attachments
- EA6C2815-832D-4C17-B689-03EBFF8ED143.jpeg (1.47 MiB) Viewed 2839 times
- Turion Rilyaloce
Here is the first model blocked in. I think I’m pretty happy with that balance of metals, leaving the characters distinguished by their solid gold plate.
I cannot stress enough now easy these inks make the process, I’m not completely dreading doing 45 of them
- Attachments
- D3602CD4-3F16-4648-91A4-01A9530E5C88.jpeg (1.01 MiB) Viewed 2834 times
- Anduil of Elithis
Really good first colour blocks! I think this works well for regular troops, giving you options to integrate more golden armour elements for elite units and characters.
- Turion Rilyaloce
That’s a really good point.Anduil of Elithis wrote: ↑Tue Jul 30, 2024 10:33 am Really good first colour blocks! I think this works well for regular troops, giving you options to integrate more golden armour elements for elite units and characters.
- Turion Rilyaloce
I’ve put down the initial drybrush for each metal. But now do I panel line for more contrast? Or is the depth good enough?
Plus - more depth and an additional coat of gloss varnish will help make them bullet proof.
Minus - add a day to cure the varnish to each model at that stage. I might be able to offset this by having batches in different states of production and stagger them.
- Attachments
- 27843779-EA40-4E0F-811B-818A79999D1A.jpeg (1001.86 KiB) Viewed 2812 times
- Anduil of Elithis
Personally, I would not do additional panel lining here, as I consider the level of depth above sufficient. But I also don't paint as well as you do, so there is that
- TyrrenAzureblade
These are probably the best third party High Elves I've seen, although I'm still a die hard for the original GW aesthetics and motifs. Can't wait to see these when you're all done!
- Turion Rilyaloce
I think you’re right, and if I ever want to finish my RnF I should probably not add too much process. When I think about it being in a block means you’re only going to see so much since there is forest through the trees effect, and the actual obscuring of the inner models. Thanks for the reason.Anduil of Elithis wrote: ↑Wed Jul 31, 2024 5:16 pm Personally, I would not do additional panel lining here, as I consider the level of depth above sufficient. But I also don't paint as well as you do, so there is that
And you are a fine painter, I enjoy checking out your work, so I appreciate your feedback.
- Turion Rilyaloce
I think they were the best balance of still looks like a HE and a little more aggressive like a Caledorian levy might be. They are nice to work with too, very receptive to inks and dry brushing which I wanted because I’m slow.TyrrenAzureblade wrote: ↑Wed Jul 31, 2024 5:51 pm These are probably the best third party High Elves I've seen, although I'm still a die hard for the original GW aesthetics and motifs. Can't wait to see these when you're all done!
- TyrrenAzureblade
Most excellent. I'm assuming you purchased them pre-printed and didn't self print? Either way, how's the print quality? They look pretty crisp in the photos you posted.Turion Rilyaloce wrote: ↑Wed Jul 31, 2024 7:05 pmI think they were the best balance of still looks like a HE and a little more aggressive like a Caledorian levy might be. They are nice to work with too, very receptive to inks and dry brushing which I wanted because I’m slow.TyrrenAzureblade wrote: ↑Wed Jul 31, 2024 5:51 pm These are probably the best third party High Elves I've seen, although I'm still a die hard for the original GW aesthetics and motifs. Can't wait to see these when you're all done!
- Turion Rilyaloce
Yes preprinted. The print quality is very good. It’s the packing that you have to worry about lol. They came with some breaks. But I’ll fix themTyrrenAzureblade wrote: ↑Wed Jul 31, 2024 8:24 pmMost excellent. I'm assuming you purchased them pre-printed and didn't self print? Either way, how's the print quality? They look pretty crisp in the photos you posted.Turion Rilyaloce wrote: ↑Wed Jul 31, 2024 7:05 pmI think they were the best balance of still looks like a HE and a little more aggressive like a Caledorian levy might be. They are nice to work with too, very receptive to inks and dry brushing which I wanted because I’m slow.TyrrenAzureblade wrote: ↑Wed Jul 31, 2024 5:51 pm These are probably the best third party High Elves I've seen, although I'm still a die hard for the original GW aesthetics and motifs. Can't wait to see these when you're all done!
- Turion Rilyaloce
Here is the gold developing, I like how it looks on the texture of the shield.
- Attachments
- E9E8F9FA-3B1E-45E5-8475-CBD80514EA15.jpeg (1015.59 KiB) Viewed 2760 times
- 1BE59B2C-5D32-4BA7-B4C8-CC97AF7D6789.jpeg (1.05 MiB) Viewed 2760 times
- Turion Rilyaloce
Metals done except for the pure white hot spots.
I have to say I’m absolutely loving the round mail. It looks a lot better to me than the rectangular scale mail, Anduil was right no panel lining needed once the bright highlights are down.
These are a joy to paint, they are fast, and look great. Great sculpts.
- Attachments
- E0B79AAE-75AE-41A7-ADCE-B04E9536BDF1.jpeg (1.1 MiB) Viewed 2755 times
- Anduil of Elithis
Glad to see this working out so well. The gold on the shield is also particularly stunning!
- Turion Rilyaloce
Thank you!Anduil of Elithis wrote: ↑Fri Aug 02, 2024 8:58 am Glad to see this working out so well. The gold on the shield is also particularly stunning!
Prince Tûrion Rilyalocë, leader of the Drakes and the Hawks army, unites Caledor and Yvresse forces under the banner of Dragon and Hawk, themed in purple, white, gold, green, and blue.
- Turion Rilyaloce
It was once a touching alliance. But now the force is mono Caledor.MikeRobert wrote: ↑Sat Aug 03, 2024 4:19 pm Prince Tûrion Rilyalocë, leader of the Drakes and the Hawks army, unites Caledor and Yvresse forces under the banner of Dragon and Hawk, themed in purple, white, gold, green, and blue.
I had a dragon sitting around and could not really explain to myself why I’d use a griffon instead. So now that I have the skill to swap the rider, I had to consolidate the power of the Drakes!
- Turion Rilyaloce
We are on bases! There is satisfaction in seeing the models base to base in a proto rank. Can’t wait to have a whole unit.
- Attachments
- 0D3F2D8C-8F11-42B7-8CA5-0770F2E2B8C7.jpeg (979.34 KiB) Viewed 2713 times
- Turion Rilyaloce
Hot spots done, just the base to go and that will be my first RnF Elf completed.
- Attachments
- F1565FA9-E441-46B3-96EF-464AD7436E26.jpeg (937.08 KiB) Viewed 2708 times
- EF0FE6E1-54C4-4921-8B8B-71B064FF0392.jpeg (944.92 KiB) Viewed 2708 times
- Turion Rilyaloce
And they are done. Can’t wait to have a block of these.
By the way, the Caledorian blood line is apparently swole.
- Attachments
- 0525EB5A-8D51-418D-BE75-75D7A7CFBCEF.jpeg (1.06 MiB) Viewed 2691 times
- 4345D0E1-4BA3-48A8-BB3D-C640463BC39A.jpeg (1.17 MiB) Viewed 2691 times
Nice!
I actually like the before and after picture for the NNM. It's great to see how well it works. They look very deadly indeed.
- Turion Rilyaloce
Thank you! Yah the process is important to display because it looks terrible until it doesn’tPrince of Spires wrote: ↑Fri Aug 09, 2024 10:03 am Nice!
