Temporary glue
Temporary glue
Hi,
I wonder what temporary gluing metod will be best (to glue riders to the horses before painting them separately, for example). Methods I've figured out or found on the net:
1. A bit of green stuff.
2. A bit of super glue
3. A bit of white glue
4. Rubber glue (?)
5. Blu tack
6. A bit of hot glue.
Hot glue is out of the question, I don't have the equipment. Options 1,2,3 I could try out without buying anything extra.
Any thoughts?
4. Rubber glue (?)
5. Blu tack
Any thoughts?
Re: Temporary glue
I always found GW's superglue to be temporary.
Amazed to find other superglue actually makes things stay stuck!
Re: Temporary glue
As a general rule I try to stay away from GW glue (of any variety really). It just doesn't stick stuff together well.
I think it depends a bit on what you hope to achieve. I use blue tack (though mine is actually white) if I want to get an idea of how stuff looks put together. The others are too sticky, and especially white glue might leave some residue you can see afterwards. For a quick look I simply hold stuff together.
Re: Temporary glue
I wanted to write the exact same thing about GW plastic glue.SpellArcher wrote:I always found GW's superglue to be temporary.
I use "blue tack" (our variety is also white) to hold the model or base in place when painting. For conversions I usually use a thin wire to pin the parts to place (it gives some room for positioning) or green stuff (it can be pried off if needed). Or both. It has the added benefit of holding the model together after permament glue is applied. I do not trust any glue after some of my models started to fall apart on slightest touch. Grrr.
Re: Temporary glue
Thanks for the answers. I want to glue my silver helms to their horses so I'll be able to field them normally and then (when I find enough time) remove the temporary glue to paint the elves and horses separately. Similarly I could use this temporary glue method to attach miniatures to their bases.
Blue tack (or is it blu tack?) would be helpful during the assembly process, that's for sure.
- Very Helpful Elf
Re: Temporary glue
Riders to horses is easy enough, and the blutack works great for that. Minis to bases is a different ballgame...Doctor wrote:Thanks for the answers. I want to glue my silver helms to their horses so I'll be able to field them normally and then (when I find enough time) remove the temporary glue to paint the elves and horses separately. Similarly I could use this temporary glue method to attach miniatures to their bases.
Re: Temporary glue
I used pins on mine. Pin in the horse, drilled hole in the riders *ahem*. Makes them much easier to transport too.
Re: Temporary glue
Way to lower the tone John
Ricold, Not site owner any more, largely absent. PM me if you want me. PM Prince of Spires if you need the head Loremaster.
Re: Temporary glue
About blue tack, is there any substantial difference between "original" and "handy" variety? I'm guessing it;s the same stuff with different packaging?
As for pinning the riders, I don't have proper drills for it. Good point about transport, though.
- Very Helpful Elf
Re: Temporary glue
This is actually what I do for painting the rider, and it worked well back when I played with unpainted minis, and had more of a need to frequently transport them. These days I already have enough painted minis to play warhammer, so painting things on horses is mostly just for fun. And since when we do play it's in my garage the need to transport is minimal. So these days I end up pinning them like you describe (it's nice to hold the legs and torso together anyway) and then just glue it to the horse as well. I'm sure I'll regret it someday, but not yet.John Rainbow wrote:I used pins on mine. Pin in the horse, drilled hole in the riders *ahem*. Makes them much easier to transport too.
You can get them off ebay for $8.00 with free shipping in the US. I'm not sure where you are, but probably you can find something similar. They are well worth it. Don't buy fancy pins either. For small stuff use a staple. For things like this a small paper clip is perfect.Doctor wrote:As for pinning the riders, I don't have proper drills for it. Good point about transport, though.
Re: Temporary glue
Seconded. I got a small pin-vice off of eBay (actually the GW drill is one of the best I've used) and use paperclips as the pins.Shannar, Sealord wrote:You can get them off ebay for $8.00 with free shipping in the US. I'm not sure where you are, but probably you can find something similar. They are well worth it. Don't buy fancy pins either. For small stuff use a staple. For things like this a small paper clip is perfect.
Re: Temporary glue
+3. I was astounded at the difference pinning made to my modelling, and I just picked up a cheap* one from GW and used paperclips.
*+GW tax!
*+GW tax!
Re: Temporary glue
Thanks for the suggestions. I'll consider pinning. I'll also buy Blu Tack.
Wouldn't it be easier to glue the pin to the rider, not the other way around? The horse is hollow inside. Is it firm enough?
Could someone maybe post a photo?
What diameter of drills do you find the most useful?
@ Ferny: why did it made so much difference?
- Very Helpful Elf
Re: Temporary glue
For sure I glue the pin to the rider. I even drill all the way up into the torso (I use the dremel for metal minis rather than a hand drill). That way the pin helps hold the mini together along with holding him on the horse.
Re: Temporary glue
Suddenly I could make joints hold! For example, old metal PG - glueing their arms (with halberd) onto the body only has a very small contact zone - add a hole and a pin and suddenly the glue has the length of the pin for contact also, and the connection isn't just flush but is also inserted.
Fixing things like broken lances and banners - same thing - tiny contact zone suddenly massively re-enforced.
I actually tend to pin a lot of things now which strictly don't need it because I value the extra hold it gives.
RE: drill size - I just use whatever it came with, but sometimes I feel I need a smaller one (e.g. sometimes it 'splits' a lance if you're drillign up the length of it).
- Very Helpful Elf
Re: Temporary glue
Honestly start with a small set. Something like this will give you options to work with, and learn what you like best. http://www.ebay.com/itm/20pc-Mini-Micro ... SwDk5UEGWU
And yes, I'm very glad I have the small bit to use on lances and the like, and staples make great pins for that. I pin pretty much everything on metal minis now, and all repairs on plastics as well.
Re: Temporary glue
I wouldn't call that set small, comparing to what's available here Generally I have options like a 0,3 - 1 mm drill set, 1-2 mm drill set etc. I guess the smaller one would be better. I can also buy single drills. Or GW, Tamiya ones.
Fixing broken lances - I also thought about that. Very useful application. It will also help to assemble my 5 ed dragon
- Very Helpful Elf
Re: Temporary glue
Yep, the old metal dragons more or less require pinning.
