It is currently Fri Jul 10, 2020 6:56 am
PostPosted: Sat Mar 14, 2015 12:53 am
I usually have low point games around 1000 points. This works great for some armies but not so great for high elves. I notice we struggle a bit at low points having less tools for certain situations then other armies would.
At what point level do we "optimize" at? Why
PostPosted: Sat Mar 14, 2015 9:09 pm
hmmm.. I generally consider that 2400 points is very optimal point cost (not only for high elven but pretty much for each armies)
But to answer why, that is whole another story ;) perhaps that is the point allowance where magic seems to be in good balance. If you go bigger games magic starts to be less significant and in smaller games magic becomes somewhat erratic especially if you have low level casters.
PostPosted: Sun Mar 15, 2015 7:50 pm
I would say you need more than 1500pts to get a decent HE list. HEs require a lot of synergy between units, etc and this isn't as easy to achieve at lower points levels.
PostPosted: Tue Mar 17, 2015 6:11 pm
wow 2400 points! That's alot of models and alot of money
PostPosted: Tue Mar 17, 2015 7:04 pm
it helps a ton if you gaming buddies isn't too strict on the proxy things. that lets you test stuff and allows you to go little bigger.
another way to "add" model counts in units is to make some kind of unit fillers. For ideas use google search "unit filler" ;) Undeads are propably the best army have unit fillers as they get tons of extra parts (usually extra hands and stuff) and making bases that only have like hand incoming from the base to represent just resurrected models is easily accepted. Allthough you better make sure your opponent agrees of using unit fillers.
PostPosted: Wed Mar 18, 2015 12:55 am
Oh there would be no problem with proxies, we proxy entire armies sometimes. Its just that I like the army I use to be completely assembled and painted. Makes it feel right and good. 2500 would increase my army by 150%. Might be worth it once 9th edition comes.
PostPosted: Wed Mar 18, 2015 12:06 pm
I think that actually you can play a decent game from 1000pts and up, 500 is a bit tougher because you run out of points after a general and a core unit. The main requirement is that you agree with your opponent to build a list aimed at having a good time and not one that tries to bring the most bad-ass stuff you can fit in a list.
If you do it this way, then that 1000 points army will look a bit like an army and have a decent chance of fighting whatever is across the table. If you don't do it this way then, as the others point out, there are some things that simply break the game because they are very hard to deal with at low points. Which then turns the game into more of a rock-paper-scissors game then it already is.
If you want to bring what-ever strong choices are in the book then I agree with the others and you need to play above 2000 pts (2400 or 2500 are the most common in my experience).
But if you just want to have a good time with friends and a fun battle, then 1000pts and up works fine.
Users browsing this forum: No registered users and 25 guests
