As the name says, the first iteration of the HE book for the 9th age.
Let the playtesting begin!
http://www.the-ninth-age.com/index.php? ... y-draft-1/
Several disclaimers:
This is still a WIP version, only the first draft that will go through extensive playtesting, so there will be some changes to this version for sure.
The missing magic item allowance for our champions is an oversight and will be dealt with at first opportunity.
All magic items are subject to change.
Path of White magic is subject to change (more so than other things listed here since it has to be agreed upon by Elves of Light (HE), Elves of Nature (WE) and Reptilians (LM)).
HE TAC Community draft 1
- ArhangelusM
The 9th Age team member:
- former Vampire Covenant Army Book Committee member
- Highborn Elves Army Book Committee member
- ArhangelusM
Re: HE TAC Community draft 1
For the lazy:
Hello everyone,
At long last, TAC Community Draft 1! Please visit the following thread for supplying feedback: Soliciting Feedback: TAC Community Draft 1. Do not leave your feedback here.
Regards,
Axiem
Elves of Light
Army Special Rules
Martial Discipline
Models with this special rule test to make Swift Reform, Combat Reform, and Restrain pursuit rolls on three dice, and may discard the highest.
Master of the Winds
If your army includes one or more models with this rule, add an additional +1 to channel attempts. If a model with this rule miscasts a spell, it counts as having rolled one power dice less than it actually did (to a minimum of 2).
Master of the Sword
Models with this rule have the Distracting special rule, which may also be used against Shooting attacks made by models in the unit’s front arc. Models with this rule strike at normal initiative while using great weapons.
Armoury
Shooting Weapons
Giant Bow
This is a Bolt Thrower Artillery Weapon with the following profile: Range 24", Strength 5, Multiple Wounds (D3), Armour Piercing (6).
Moonlight Arrows
When fired from a normal Bow, Moonlight Arrows grants +1 to Wound and Armor Piercing (1) and have the Magical Attacks and the Flaming Attacks special rules.
Other Equipment
Lion Fur. Model on Foot only. Scaly Skin (6+), Scaly Skin (5+) against Shooting attacks. May not be taken by a model with Dragonforged Armour.
Dragonforged Armour
Heavy armour. The wearer has Fireborn and Ward Save (6+). This item cannot be taken by a model that has Lion Fur.
Magic items
White Sword 40 pts
Magic Weapon. Type: Great Weapon. Multiple Wounds (2).
Raider’s Bow 25 pts
Magic Weapon. Type: Longbow . Range 30”, Strength As user +1 , Multiple shots (3).
Armor of Light 25 pts
Magic Armor: Heavy Armor. The bearer and his unit have Ward Save (6+) and the Magic Attacks special rule.
Cloak of the Stars 25 pts
Talisman. Enemy spells cast against the bearer or his unit suffer -3 to their casting value. This can cause the spell to fail.
Radiant Gem 35 pts
Enchanted Item. Bound Spell. Power Level 5. During army selection, pick the Signature Spell of any Battle Path or the Path of White Magic. The Gem contains that spell. Furthermore the bearer has the Channel Special Rule.
Gleaming Robes 45 pts
Enchanted Item. Mage or Archmage only. Wearer has Ethereal special rule, but can still join units. Bearer may not make attacks.
Talisman of the Trickster 10 pts
Enchanted Item. One use only. Use at the start of combat phase. The bearer may re-roll all to-hits and to-wounds rolls until the end of the phase. Wounds caused by the bearer must re-roll all successful saves of any kind. At the end of the phase the wearer suffers 1 wound with no saves of any kind allowed.
Book of the Wizard Tower 40 pts
Arcane Item. Once per magic phase, the bearer can reroll a single power or dispel dice when making casting or dispelling attempt, provided the dice was not a '6'.
Banner of Nullification 75 pts
Standard. Wizards within 6" of the bearer cannot cast spells. Magic Items (other than Banner of Nullification) within 6" have no effects (revert to mundane version of the items).
Banner of Sorcery 50 pts
Standard. The bearer has the Channel Special Rule. Furthermore any friendly mages within 6" add +1 to all Casting rolls.
Army List
LORDS
High Prince 140 pts
M WS BS S T W I A Ld
HIgh Prince 5 7 7 4 3 3 8 4 10
Infantry Base size: 20x20mm
Unit size 1
Special Rules: Martial Discipline, Supernatural Reflexes
Options:
May take Magic Items Up to 100 pts
May take Lion Fur 6 pts
May take Dragonforged Armor 12 pts
May take Heavy Armour 6 pts
May take a Shield 3 pts
May take a Longbow 3 pts
May take a weapon (one choice only)
...Great Weapon 6 pts
...Halberd 3 pts
...Lance 6 pts
...Additional Hand Weapon 3 pts
...Spear3 pts
May take a mount (one choice only)
...Elvish Horse 15 pts
...Griffon 125 pts
...Giant Eagle 40 pts
...Dragon Youngblood 170 pts
...Dragon 250 pts
...Horse Chariot 60 pts
Archmage 175 pts
Archmage 5 4 4 3 3 3 5 1 9
Unit size 1
Special Rules: Master of the Winds, Martial Prowess, Supernatural Reflexes
Magic: Level 3 Wizard. Generate spells from Path of White Magic or any of the Battle Magic Paths
Options:
May become a Level 4 wizard 50 pts
...Griffon 100 pts
...Dragon 250 pts
High Warden of the Flame 190 pts
HIgh Warden 5 7 6 4 3 3 8 3 9
Unit size 1
Equipment: Halberd, Heavy Armor
Special Rules: Sacred Warden, Martial Prowess, Supernatural Reflexes, Ward Save (4+), Immune to Psychology
Options:
...Fire Phoenix 150 pts
...Ice Phoenix 200 pts
Sacred Warden: A High Warden of the Flamed and Protectors of the Flame in the same unit have Holy Attacks. When mounted on a Fire or Frost Phoenix, increase the Phoenix’s Ward Save to 4+ and add +1 to all rolls on the Rebirth table.
Master of Paths 210 pts
Master of the Paths 5 7 4 4 3 3 7 3 9
InfantryBase size: 25x25mm
Unit size 1
Equipment: Greatsword, Heavy Armor
Special Rules: Master of All Paths, Master of the Sword, Master of the Winds, Martial Discipline, Supernatural Reflexes
Options:
May become a Level 3 wizard 35 pts
Master of all Paths: The wizard knows the signature spell from each of the eight Paths of Battle Magic, instead of generating spells normally.
HEROES
High Captain 70 pts
HIgh Captain 5 6 6 4 3 2 7 3 9
Unit size 1
Options:
May be the Battle Standard Bearer 25 pts
May take Magic Items Up to 50 pts
May take Lion Fur 4 pts
May take Dragonforged Armor 8 pts
May take Heavy Armour 4 pts
May take a Shield 2 pts
May take a Longbow 2 pts
...Great Weapon 4 pts
...Halberd 2 pts
...Lance 4 pts
...Additional Hand Weapon 2 pts
...Spear 2 pts
...Elvish Horse 10 pts
...Griffon 150 pts
...Giant Eagle 50 pts
Dragon Wizard 250 pts
Dragon Wizard 5 4 4 3 3 2 5 1 8
Unit size 1
Equipment: Lance
Mount: Dragon Youngblood
Special Rules: War-Soul, Fiery Adept, Martial Discipline, Supernatural Reflexes
Magic: Level 1 Wizard. Generate spells from Path of Fire
Options:
May become a Level 2 wizard 35 pts
War-Soul: A Dragonmage always generates the spell Flaming Swords in addition to his normal spells. If the Flaming Sword is rolled while generating, simply reroll the die. May not participate in an Aided DIspel.
Fiery Adept: Damage caused by the Path of Fire attribute Raging Fire inflict D6 Strength 4 Flaming Attacks instead of D3.
Mage 80 pts
Mage 5 4 4 3 3 2 5 1 8
Unit size 1
Special Rules: Master of the Winds, Martial Discipline, Supernatural Reflexes
Magic: Level 1 Wizard. Generate spells from Path of White Magic or any of the Battle Magic Paths
Options:
Coastal Sentinel 70 pts
Coastal Sentinel 5 5 6 4 3 2 6 2 8
Unit size 1
Equipment: Light Armor, Bow.
Special Rules: Nautical Discipline, Martial Discipline, Supernatural Reflexes, Quick to Fire, Weapon Master
Options:
May be the Battle Standard Bearer 25pts
...Lance 4 pts
...Spear2 pts
...Hawk Chariot 65 pts
Nautical Discipline: While mounted, a Coastal Sentinel and any Hawk Chariot in his unit has a 5+ Ward Save and ignores Dangerous Terrain Tests. If a Coastal Sentinel is the Army Battle and on foot, he and his unit can immediately make a combat reform if it is successfully charged immediately after enemy models have been brought into contact.
Queen’s Handmaiden 75 pts
Queen’s Handmaiden 5 5 7 4 3 2 6 2 8
Unit size 1
Equipment: Light Armor, Bow, Moonlight Arrows.
Special Rules: Fleet Footed, Multiple Shot (3), Martial Discipline, Supernatural Reflexes
Options:
Fleet Footed: The Queen's Handmaiden and any Queen's Guards in the same unit have the Quick to Fire Special Rule. If she is the Army Battle standard, she and her unit counts as having the Fast Cavalry Special Rule when fleeing.
Hello everyone,
Regards,
Axiem
Elves of Light
Army Special Rules
Martial Discipline
Master of the Winds
Master of the Sword
Armoury
Shooting Weapons
Giant Bow
Moonlight Arrows
Other Equipment
Dragonforged Armour
Magic items
White Sword 40 pts
Raider’s Bow 25 pts
Radiant Gem 35 pts
Army List
LORDS
High Prince 140 pts
Unit size 1
Options:
...Halberd 3 pts
...Lance 6 pts
...Spear3 pts
...Griffon 125 pts
...Dragon 250 pts
Archmage 175 pts
Unit size 1
Options:
...Griffon 100 pts
...Dragon 250 pts
Unit size 1
Options:
Unit size 1
Options:
HEROES
High Captain 70 pts
Unit size 1
Options:
...Halberd 2 pts
...Lance 4 pts
...Spear 2 pts
...Griffon 150 pts
Unit size 1
Equipment: Lance
Options:
Mage 80 pts
Unit size 1
Options:
Unit size 1
Options:
...Lance 4 pts
...Spear2 pts
Unit size 1
Options:
- ArhangelusM
CORE
Elvish Spearmen 70 pts
Elvish Spearmen 5 4 4 3 3 1 5 1 8
Unit size: 10
Equipment: Light Armor, Shield, Spear, Bows (Coastal Guard only)
Special Rules: Fight in Extra Rank, Martial Discipline, Supernatural Reflexes, Quick to Fire (Coastal Guard only), Weapon Master (Coastal Guard only)
Options:
May add up to 40 additional models 7 pts / model
May take Heavy Armor 2 pt / model
May be upgraded to Coastal Guard 4 pts / model
...A single unit of Coastal Guard up to 30 may have Ambush 2 pts / model
May upgrade one Elvish Spearmen/Coastal Guard to each of the following:
...Champion 10 pts
...Musician 10 pts
...Standard Bearer 10 pts
...- may take a Magic Banner up to 25 pts
Elvish Archers 70 pts
Archer 5 4 4 3 3 1 5 1 8
Unit size: 10
Equipment: Bow.
Options:
May add up to 20 additional models 7 pts / model
May take replace Bows with Longbows 2 pt / model
May take Light Armor 1 pt / model
May upgrade one Archer to each of the following:
...Champion 10 pts
...Musician 10 pts
Elvish Heavy Cavalry 100 pts
Rider 5 4 4 3 3 1 5 1 8
Elvish Horse 9 3 0 3 3 1 4 1 3
Cavalry Base size: 25x50mm
Unit size: 5
Equipment: Heavy Armor, Lance, Natural Armor
Special Rules: Martial Discipline, Supernatural Reflexes (Rider only)
Options:
May add up to 10 additional models 20 pts / model
May take Shields 3 pt / model
May upgrade one Rider to each of the following:
...Champion 10 pts
...Musician 10 pts
Elvish Light Cavalry 80 pts
Unit size: 5
Equipment: Light Armor, Light Lance
Special Rules: Martial Discipline, Supernatural Reflexes (Rider only), Fast Cavalry
Options:
May add up to 5 additional models 16 pts / model
May take Natural Armor 2 pts / model
May take Bows 1 pt / model
...Champion 10 pts
...Musician 10 pts
SPECIAL
Sword Masters 70 pts
Sword Master 5 6 4 3 3 1 6 2 8
Unit size: 5
Equipment: Great Weapon, Heavy Armor
Special Rules: Masters of the Sword, Martial Discipline, Supernatural Reflexes
Options:
May add up to 25 additional models 14 pts / model
May upgrade one Sword Master to each of the following:
...Champion 10 pts
...Musician 10 pts
...Standard Bearer10 pts
...- may take a Magic Banner up to 50 pts
Lion Guard 130 pts
Lion Guard 5 5 4 4 3 1 5 1 8
Unit size: 10
Equipment: Great Weapon, Heavy Armor, Lion Fur
Special Rules: Monster Hunters, Martial Discipline, Swiftstride, Supernatural Reflexes, Bodyguard (General)
Options:
May add up to 20 additional models 13 pts / model
May upgrade one Lion Guard to each of the following:
...Champion 10 pts
...Musician 10 pts
Monster Hunters: Models with this rule have the Multiple Wounds (2) special rule against Monstrous Cavalry and Monstrous Beasts.
Protectors of the Flame 150 pts
Protector 5 5 4 3 3 1 6 1 9
Unit size: 10
Special Rules: Fight in Extra Ranks, Immune to Psychology, Martial Discipline, Supernatural Reflexes, Ward Save (4+)
Options:
May add up to 20 additional models 15 pts / model
May upgrade one Protector to each of the following:
...Champion 10 pts
...Musician 10 pts
Knights of the Dragon Realm 160 pts
Knight 5 5 4 4 3 1 6 2 9
Unit size: 5
Equipment: Dragonforged Armor, Shield, Lance, Natural Armor
Special Rules: Martial Discipline, Supernatural Reflexes (Knight only)
Options:
May add up to 10 additional models 32 pts / model
May upgrade one Knight to each of the following:
...Champion 10 pts
...Musician 10 pts
...- may take a Magic Banner up to 75 pts
Shadow Watchers 65 pts
Shadow Watcher 5 5 5 3 3 1 5 1 8
Unit size: 5
Equipment: Bow, Additional Hand Weapon, Light Armor
Special Rules: Martial Prowess, Poisoned Attacks, Supernatural Reflexes, Skirmishers, Scout
Options:
May add up to 10 additional models 13 pts / model
May upgrade one Shadow Watcher to the following:
...Champion 10 pts
Crew (2) - 4 4 3 - - 5 1 8
Elvish Horse (2) 9 3 - 3 - - 4 1 -
Chariot - - - 5 4 4 - - -
Chariot Base size: 50x100mm
Unit size: 1
Equipment: Light Lance, Longbow, Heavy Armour
Special Rules: Martial Discipline, Supernatural Reflexes (Crew only), Free Reform
Options:
May add up to 3 additional models 60 pts / model
May add Vanguard to the unit 10 pts / model
Lion Chariot 90 pts
Crew (2) - 5 4 4 - - 5 1 8
Lion (2) 8 5 - 5 - - 4 2 -
Unit size: 1
Equipment: Great Weapon, Heavy Armour, Natural Armor, Scythes
Special Rules: Martial Discipline, Supernatural Reflexes (Crew only), Stubborn
Hawk Chariot 65 pts
Hawk (1) 2 5 - 4 - - 4 2 -
Chariot - - - 4 4 4 - - -
Unit size: 1-3
Equipment: Light Lance (Crew only), Longbow (Crew only), Light Armour
Special Rules: Martial Discipline, Skirmishers, Quick to Fire, Supernatural Reflexes (Crew only), Fly (9)
Options:
May add a Giant Bow 25 pts / model
May add a third Crew 10 pts / model
Coast Guard Reaper 55 pts
Machine - - - 5 4 4 - - -
War Machine Base size: 60 mm round
Unit size: 1
Equipment: Elvish Bolt Thrower, Light Armour
Options:
May purchase Repeating Shot 20 pts
Elvish Bolt Thrower: Bolt Thrower Artillery Weapon with the following profile: Range 48", Strength 6, Multiple Wounds (D3), Armour Piercing (6). If the Repeating Shot option is purchased, may also fire as Volley Gun Artillery Weapon with the following profile: Range 48", Strength 4, Armour Piercing (1), Multiple Shots (6).
Unit size: 10
Options:
...Champion 10 pts
...Musician 10 pts
Unit size: 10
Equipment: Bow.
Options:
...Champion 10 pts
...Musician 10 pts
Unit size: 5
Options:
...Champion 10 pts
...Musician 10 pts
Unit size: 5
Options:
...Champion 10 pts
...Musician 10 pts
SPECIAL
Unit size: 5
Options:
...Champion 10 pts
...Musician 10 pts
Lion Guard 130 pts
Unit size: 10
Options:
...Champion 10 pts
...Musician 10 pts
Unit size: 10
Options:
...Champion 10 pts
...Musician 10 pts
Unit size: 5
Options:
...Champion 10 pts
...Musician 10 pts
Unit size: 5
Options:
...Champion 10 pts
Unit size: 1
Options:
Lion Chariot 90 pts
Unit size: 1
Hawk Chariot 65 pts
Unit size: 1-3
Options:
Unit size: 1
Options:
- ArhangelusM
RARE
Ice Phoenix 200 pts
Ice Phoenix 2 5 0 5 5 5 3 5 8
Monster Base size: 50x100mm
Unit size: 1
Special Rules: Fly (8), Ward Save (5+), Scaly Skin (5+), Magical Attacks, Chill Aura
Chill Aura: Enemy units in base contact with one or more models with this rule has -3 Initiative and -1 Strength (to a minimum of 1).
Fire Phoenix 2 5 0 5 5 5 4 3 8
Unit size: 1
Special Rules: Fly (9), Ward Save (5+), Magical Attacks, Fireborn, Flaming Attacks, Flame Swoop, Rebirth
Flame Swoop: During the Remaining Moves sub-phase models with this rule can Burn a unengaged enemy unit. Nominate one unit which the model moved over this turn. This unit suffers D6 hits, plus additional D3 hits for each rank the unit has. These hits are Strength 4 with Flaming Attacks and shooting attacks.
Rebirth: When a model with this rule is removed as a casualty, place a marker centered on the final position of the model.
At the start of each of your remaining moves sub-phases, roll a D6 for each marker.
1: Dead Embers: Remove the marker
2-3: Dying Flames: Marker remains, but subtract 1 from your next Rebirth roll
4-5: Kindled Embers: Marker remains, but add 1 to your next Rebirth roll
6: Phoenix Reborn: Place a summoned Flame Phoenix within 3" from the marker and remove the marker. If you cannot place the model, treat the result as a 1.
Giant Eagle 50 pts
Giant Eagle 2 5 0 4 4 3 4 2 8
Monstrous BeastBase size: 50x50mm
Unit size: 1
Options:
May take Supernatural Reflexes 10 pts
May take Armor Piercing (1) 5 pt
Queen’s Guard 65 pts
Queen’s Guard 5 5 5 3 3 1 5 1 8
Unit size: 5
Equipment: Bow, Light Armor
Special Rules: Moonlight Arrows, Martial Prowess, Supernatural Reflexes
Options:
May add up to 15 additional models 13 pts / model
May purchase Spears 1 pt / model
May Skirmish 2 pts / model
May upgrade one Queen’s Guard to each of the following (Musician and Standard Bearer cannot be taken if Skirmish):
...Champion 10 pts
...Musician 10 pts
MOUNTS
The Mounts section is for character mounts. Non-character mounts follow the rules given under their respective entries.
Elvish Horse
War Beast Base size: 25x50mm
Options:
May take Natural Armor 5 pts
Giant Eagle
Monstrous Beast Base size: 50x50mm
Options:
May take Armor Piercing (1) 5 pts
Griffon
Griffon 6 5 0 5 5 4 5 4 5
Unit size: 1
Special Rules: Fly (8), Large Target, Fear
Options:
May take Armor Piercing (1) 10 pts
May take Supernatural Reflexes 15 pts
Dragon Youngblood
Dragon Youngblood 6 5 1 5 5 5 3 4 9
Special Rules: Fly (8), Large Target, Scaly Skin (3+), Breath Weapon (Strength 4 Flaming Attacks)
Dragon
Dragon 6 5 1 6 6 6 3 5 9
One of a Kind
Options:
If mounted by a High Prince, the Dragon may be upgraded to Ancient Dragon (100 pt), giving the dragon +1 WS, S, T, W, A
Ice Phoenix 200 pts
Unit size: 1
Unit size: 1
Giant Eagle 50 pts
Unit size: 1
Options:
Unit size: 5
Options:
...Champion 10 pts
...Musician 10 pts
MOUNTS
Elvish Horse
Options:
Giant Eagle
Options:
Griffon
Unit size: 1
Options:
Dragon Youngblood
Dragon
One of a Kind
Options:
- ArhangelusM
Please note:
Path of White Magic is still being agreed upon by all the armies who will use it. This is the current draft, based on feedback we have received from the Rules team, along with our and other feedback.
Like everything (perhaps more so), this is subject to heavy change.
Axiem wrote:
Name Casting Value Type Duration Effect
Hand of Glory Attribute Range 12"Augment Instant Any friendly unit gains +1 to WS, BS, I, or M (including Fly values) to a maximum of 10. Each unit may only receive the same bonus once per turn.
0: Soul Quench 9+/13+ Range 24" Hex, Missile, Damage Instant Target suffers 2D6/3D6 Strength 4 hits.
1: Drain Magic 9+ Range 24"Hex/Augment, Focused Instant All Augments on enemy units or all Hexes on friendly units are removed.
2: Apotheosis 5+10+ Range 12"Augment Instant Target recovers 1. If boosted, model also receives +1 Strength.
3: Walk Between World 9+16+ Range 24"Augment Instant Target makes a 10"/20" Ethereal Magical Move
4: Shield of the White Tower 9+16+ Range 24"Augment Lasts one Turn Target unit gains Ward Save (5+) / All friendly units within 12" gain Ward Save (5+).
5: Arcane Unforging 14+ Range 24"Hex, Direct, Focused,Damage Instant Target suffers 1 hit with Metalshifting. Then a randomly determined magic item carried by the target (ignore 'one use only' items that have already been used) is destroyed.
6: Fiery Convocation 14+19+ Range 24"Hex, Direct,Damage Remains in Play At the end of each magic phase, each model in the target unit suffers a Strength 3/4 hit with Flaming Attacks.
- Swordmaster of Hoeth
- Southern Sentinel
Thanks for posting, some people don't have the account on 9th Age forum and you need to be registered in order to see that post.
hi guys,
looks great,well done!
any updates on white magic?
also, i am not sure of the role of a dragon young blood? costs more than a griffon but not as good, if it was opened up to the high captain it could be interesting maybe?
loving the swordmasters in their current form, i have seen some hassle on the 9th forum though and hope they don't change as they are now only slightly better in defense and slightly worse in attack than 7th. I6 is essential for them not to get steamrolled i think by any other core elf. if the complaints persist the unit size could be lowered a little bit maybe?
all in all, good work guys!
Now that the local gaming centers 8th edition tournament has had its last hurrah our gaming club are now flipping over to 9th age rules (a couple of ET games as well to finish off an active ET campaign). I'll post some feedback from myself and opponents as we go but you can largely ignore it as I dont know what i'm talking about!
