It is currently Sun Jul 21, 2019 10:40 am
 Post subject: Shield of the Wyrm
PostPosted: Wed Sep 09, 2015 8:30 pm
Hi all, sorry but I do not know the name in english. I am referring to a magic item (Armour) in the HE Army book. It costs 15 ponts and it grants and armour save of 4+.
The question is. Can I use it in combination with an Heavy/Dragon Armour in order to get a 2+ Armour Save?
If not, how does am I suppose to use it?
Thank you in advance
I see the world old
I see the world dead
Under a pale grey sky, We shall ARISE
 Post subject: Re: Shield of the Wyrm
PostPosted: Wed Sep 09, 2015 9:10 pm
There isn't a magic item which gives a 4+ armour save in the HE book; there is a 15 point magic armour item in the HE book is the Shield of the Merwyrm. It's a magic shield which gives the user a 4+ parry save that can be used even if the character is also using a one-handed magical weapon. Being a shield it also gives +1 to your armour. Perhaps that's what you were thinking of?
PostPosted: Wed Sep 09, 2015 10:05 pm
oh.. yes.. that is the one.
Basically is like to have a Ward Save of 4+ but only in CC, right?
So Heavy/Dragon Armour + Shield of the Merwirm + a Mount (Maybe a Dragon) = 3+ AS and 4+Parry Save/Ward Save
ok?
Can I also have a normal Ward Save then? like 3+ Armour Save, 4+ Parry Save, and the maybe a TAlisma with a 4+ Ward Save for a total of 3 actual saves? I don't think this is possible right?
and also... Silver Helmes and Dragon Princes, after the turn they charge, use a hand weapon+shield. Do they benefot from the parry save of 6+? (ok, DP have anyway a 6+ Ward Save.. so it is not so applicable I guess)
I see the world old
PostPosted: Thu Sep 10, 2015 1:14 am
You cannot use Parry whilst you are mounted. So the best you can have is Heavy/Dragon Armour + Shield of The Merwyrm -> 4+/4++ (parry).
You can have a normal ward save.
no. Parry is only when you are non-mounted.
PostPosted: Thu Sep 10, 2015 4:15 am
sorry but I didn't get it properly (-> 4+/4++ ?? Double ++?? what is it?). Do you mean that I can use first Armour Save, then the parry save and then, as last, the Ward Save? 3 saves on a row?
Where is it written, if you can/want to provide the page, that it is only on models on foot. Because I didn't read it.
I see the world old
PostPosted: Thu Sep 10, 2015 7:04 am
You get a 4+ armour save and then (in some cases) a 4+ parry save. You can only get 2 kinds of saves so armour and either parry/regeneration/ward.
The rules for when you get to take a parry save are in the main rulebook, one of the restrictions is being on foot.
PostPosted: Thu Sep 10, 2015 6:08 pm
Young Eataini Prince
Page 88, second column. 'If a warrior is fighting with a hand weapon and a shield, then he has a 6+ ward save'. Further down - '...nor can it be used by mounted models'.
So parry saves are ward saves, but only used in combat. Concerning multiple ward saves, see page 44 - 'If a model has more than one ward save, simply use the best'.
"Eatainian jerks…" -Headshot
PostPosted: Wed Sep 30, 2015 6:06 pm
When people post 4+/4++, this means 4+ armor save and then a 4+ ward save. So if you saw 3+/5++, it would be a 3+ armor save and a 5+ ward save. The "++" means ward save, usually. As Parry is a ward save, it can be reflected in this way.
thelordcal wrote:
Or he uses his big a$$ banner pole as a great weapon...
wisetiger7 wrote:
That's what she said.
Asurion Whitestar wrote:
I would normally delete such an off topic post, but this is just too good. Classic..!! :)
