It is currently Mon Jul 22, 2019 11:45 am
PostPosted: Fri Aug 21, 2015 5:28 pm
Hi all,
it has been a while I do not enter Ulthuan. I have been travelling through the old World in search of Glory :D
The question is simple:
- who win between the ability of the VC Bat Swarm to give Always Strike Last to unit in base contact and HE Always Strike First ule?
Thank you in advance
I see the world old
I see the world dead
Under a pale grey sky, We shall ARISE
PostPosted: Fri Aug 21, 2015 6:29 pm
Batswarm (in terms of rerolls)
if you have ASF + ASL you strike at initiative order and don't get rerolls, as they cancel out each other. Usually it is considered that multiple instances of ASF and ASL cannot be combined, so bat swarm against our great weapon dudes should still be in initiative roll.
PostPosted: Sun Aug 23, 2015 6:51 am
Ok thank you. It seems fair.
But I have a further question: do the HE loose ASF in such case only against the Batswarm or, in case of a multiple combat such for example HE SM vs batswarm + Skeletons, they loose it also vs skeletons?
thnak you again
I see the world old
PostPosted: Sun Aug 23, 2015 5:44 pm
I take your question was "Does it only affect models that are in basecontact" then answer is no. It will affect the whole unit (and every enemy (from bat perspective) unit in base contact with them) including any characters. On the bright side our frost phoenix blizzard aura will also work against whole unit and will be really good against other elves as it allows us to regain asf and strike truly first ;)
PostPosted: Mon Aug 24, 2015 2:06 am
thnak you again
In this case the ASL special rule is conferred to the unit in B2B. Thus the effect matters when they fight both the bats and the skellies. The rule is not written such that it only affects them against the bats (i.e. when fighting this unit they get ASL).
PostPosted: Mon Aug 24, 2015 5:21 pm
ok perfect. Thanks both
as a side question: in such case, do they still get the re-roll to hit for equal of higher initiative?
I see the world old
