It is currently Sat Feb 16, 2019 8:19 pm
PostPosted: Tue May 26, 2015 12:29 pm
Guys I've read and re-read both the rulebook and the appropriate army books, but for the life of me i cant figure out where the rules are for shooting at large targets that are IN units (Dark Elf cauldron of blood or Skaven screaming bell for example).
Under general rules, you can't 'pick' targets when shooting at a unit - but these things are large targets - surely there is some way of targeting them specifically? Please tell me i don't have to wipe out an entire unit of 40 witch elves, or 50 stormvermin, before i can shoot at the large target?
PostPosted: Tue May 26, 2015 12:47 pm
I don't have my books handy right now, but I'm pretty sure you can pick out a model if it's not the same unit type. So cavalry attached to infantry unit, monstrous cavalry in cavalry, etc. Also I think there might be a blurb in the skaven book about shooting at the bell/furnace, not sure if the DE book has anything. I'll have to check when I get home.
PostPosted: Tue May 26, 2015 12:57 pm
The screaming bell has troop-type 'unique' and has its own rules for shooting at it. Check the skaven army book for details. I think you can chose which one you're shooting at, either the unit or the bell.
In general, if there are no special rules included in the armybook entry, I would refer to shooting at characters in units (I think most of these things are sort of characters or at least character mounts), see p98:
"if there are fewer then 5 R&F models or if the character is of a different troop type ... the controlling player decides who is hit, but must allocate one hit on each model before he can add a second hit on a model."
That said, I guess most of them have their own rules for these sorts of situations.
PostPosted: Tue May 26, 2015 1:08 pm
If you have a cannon you can snipe out things that have a different unit type inside another unit, since they will not get their look out sir. That is the general rule for things that shoots with templates (a cannon also shoots with a template). However our bolt throwers do not use a template, because it is BS shooting and hence you can't "pick" targets inside units. Unless the situation is like Rod describes it.
PostPosted: Tue May 26, 2015 1:12 pm
Ah yes i see the section in the Skaven book now, The cauldron however is troop type chariot - so wouldnt have its own unique rules. although it IS only available as a character mount, so i dont know how that affects it either :S
PostPosted: Tue May 26, 2015 1:13 pm
Cannons were my plan ;) (i have a few allies !)
PostPosted: Tue May 26, 2015 10:35 pm
So as best I can tell, you're going to need a cannon. The troop type is chariot, and being a character mount we treat it like a ridden monster. Normally ridden monsters can't join units, but the cauldron is an exception. Characters in units can't be singled out (unless you have sniper which we don't), so unfortunately you will have to mow down all but five witch elves to hit the cauldron. Unless there's a FAQ, but I couldn't find one.
PostPosted: Wed May 27, 2015 10:25 am
I can think of one spell in high magic that will do just that :wink:
