It is currently Mon Jul 22, 2019 11:46 am
Post new topic Reply to topic  [ 15 posts ]
 Post subject: Alith and piecing ranks
PostPosted: Thu Apr 09, 2015 6:18 pm
Hi
I was wondering how the piercing ranks worked for Alith since he now shoots together with the rest of the unit.
Let's say that he shoots together with a reaver bow noble against a unit of Skullcrusher. The reaver bow delivers 1 wound after saves and Alith delivers 2. Is the bolt from alith's bow then allowed to pierce the rank?
PostPosted: Thu Apr 09, 2015 7:00 pm
Gut feeling is yes but I'll get back to you later when I have my rulebook handy.
PostPosted: Thu Apr 09, 2015 7:05 pm
I don't think shooting is simultaneous like combat, it happens as it happens except that all models in a unit needs to shoot before another does. You could ping off a wound with the reaver bow, then another one with shadow warriors, then a third with Alith. Then his bolt goes on and does another wound, and then you hit with an RBT and do two more and pierce another rank, etc. Unless I'm rolling the dice, in which case no wounds would be dealt.
PostPosted: Fri Apr 10, 2015 1:06 am
Shooting from the same unit is simultaneous, it is not sequential. Shooting RBT then say shadow warriors with noble reaver bow with alith is fine this part is sequential.
Dragon fire wrote:
Hi
yes it would pierce rank as it is a bolt thrower type weapon. The question is how do you allocate the wounds since shooting from the same unit is simultaneous. I would probably agree that you can allocate the wounds sequentially but i'm not 100% sure.
PostPosted: Fri Apr 10, 2015 2:52 am
I stand corrected.
Reading through the shooting section again just now makes me think the initial wounds are all applied at the same time. So we tally up the wounds and remove casualties from the unit. Assuming we did enough wounds to take off a model Alith's shot will continue into the next rank, and so forth until it stops killing models.
PostPosted: Fri Apr 10, 2015 7:46 am
Maybe randomize wounds from different sources.
PostPosted: Fri Apr 10, 2015 10:41 am
As the shooting from the unit is simultaneous, I believe you get to choose the order that you resolve it as it's your turn.
Refer to the sequencing rule on, I think, page 10.
So if you chose to have Alith's shot resolved last, then it would pass through to the next rank.
PostPosted: Fri Apr 10, 2015 11:35 am
Can he also shoot through ranks of skirmishers?
PostPosted: Sat Apr 11, 2015 4:02 am
Skirmishers don't have ranks.
PostPosted: Sat Apr 11, 2015 7:35 am
BTW in part "Skirmishers and charging" several times mentioned skirmisher ranks. They have 0 ranks for combat resolution purposes.
But do they have files? :)
PostPosted: Sat Apr 11, 2015 4:19 pm
Sort of. Over in the light troops paragraph it says skirmishers always count as having 0 ranks. Logically, (lol, this is GW we are talking about here) if there are 0 ranks there can't be any files either. The models are physically arranged in ranks and files like any other warhammer unit, but for game purposes they are considered to have 0 ranks (and presumably 0 files).
PostPosted: Mon Apr 13, 2015 1:06 am
+1
PostPosted: Tue Apr 14, 2015 8:52 am
I actually just found this in the warhammer rulebook FAQ from GW:
- Page 77 – Special Rules, Skirmishers, Light Troops. Change “[...]zero ranks[...]” to “[...]zero ranks in combat[...]”.
So it would seem that you can pierce through ranks of skirmishers.
PostPosted: Tue Apr 14, 2015 9:50 am
If skirmishers have 0 ranks then they should not be able to fight from second and third (for HE) ranks. Probably they cant even fight in melee at all because they have 0 ranks and have no frist rank :lol:
PostPosted: Wed Apr 15, 2015 2:40 am
:lol: RAW taken to its logical extreme
RM's High Elf Plog
High Elves: 9 Painted, 112 Remaining
