At the end of the book it says that you get more combat result if more units charge. p.179
At page.58 it says you get +1 combat res if one or more units charge, but at the same page
they clearly say that flank charges do not stack.
You only get +1 when charging, right? no matter the amount of chargers?
/bbird
Multiple chages give more combat res?
Re: Multiple chages give more combat res?
Yes. +1 for any number of charges for that turn. So yu have two units simultaneously charging an enemy in the front, both charges are successful, then just a +1 to combat res for the charges.
If the charges are staggered between multiple turns, happens when units are locked in multiple turn combats, then you get a +1 for any new charges into the existing combat.
My Plog - Tele's Torpid Painting Log
