Loremaster magic
Loremaster magic
If I use the loremaster sig spells, do I get the attribute bonus?
Re: Loremaster magic
Yes. You always get the lore attribute, no matter the caster. Even bound items benefit.
Not sure on a rules reference for you at the moment but seach for lore attribute in the BRB and I'm sure you'll find what you're looking for.
Do you think sig spells or high magic is better for buffs and debuffs?
I'd go with signatures - you're spoiled for choice between Wildform, Iceshard, Miasma and Earthblood. Besides, in the End Times he gets 56 spells to chose from!
I was under the impression that since the loremaster's rules replace the normal spell selection process, he would still have the signature spells rather than knowing every spell of the eight lores.RE.Lee wrote:Besides, in the End Times he gets 56 spells to chose from!
High magic only has 3 direct ways to buff or debuff; the lore attribute, Hand of Glory and Drain Magic. The Lore attribute is great, but hard to use. Drain Magic is situational, because it's used to get rid of an enemy buff or debuff. Hand of glory is less effective than Miasma (because -3 to WS will make most infantry and cav hit our Elites on 5s). The Signature spells include Wildform (very good), Iceshard Blizard (good), Miasma (useful most of the time) and Earthblood (great if you don't have a ward or regen save).SquidVicious405 wrote:Do you think sig spells or high magic is better for buffs and debuffs?
This doesn't tell the whole story though, because High Magic has some interesting ways to effect combat indirectly. Walk Between Worlds can allow you to get a unit out of danger, set up a flank charge, close with the enemy (giving them less turns to shoot or magic you or giving you more time for combat) or bring up another unit in support if the combat lasts multiple rounds. Arcane Unforging can break a crucial item on a nasty character (such as a Ward save, Dawnstone, +S Sword, Stubborn hat), which could allow you to win combat because the character is does less damage or dies more quickly. Firery Convocation can quickly kill off multiple ranks of cheap Steadfast infantry.
It really depends on what you want. The Loremaster provides better tactical combat support. He's much better at affecting the outcome of a combat happening this turn. High Magic can help in combats this turn, but is more effective when used to tilt the odds of a combat in your favor a couple of turns before.
http://www.ulthuan.net/forum/viewtopic. ... 90#p892871theviking wrote:I was under the impression that since the loremaster's rules replace the normal spell selection process, he would still have the signature spells rather than knowing every spell of the eight lores.
The Loremaster of Hoeth is the explicit example they use in the rules for spells generation. He does know every spell from every lore he originally knows a spell from, which makes 56 spells as RE.Lee wrote.
If you use Swordmasters, getting miasma off gives you a 2/3 chance that any WS4 infantry will be hitting you on 5s, and iceshard blizzard means hitting on 6s. That's my favorite combo with the Loremaster. That's better than most buffs in my opinion.
Iluvatar wrote:http://www.ulthuan.net/forum/viewtopic. ... 90#p892871theviking wrote:I was under the impression that since the loremaster's rules replace the normal spell selection process, he would still have the signature spells rather than knowing every spell of the eight lores.
does he also get to reroll his casting attempts too with the upgraded loremaster rule?
Read the text.
I short: no.
Wizards that were not loremasters before the End Times are now the equivalent of previous loremasters (ie they know all the spells for their domain).
Wizards that do have the Loremaster special rule can re-roll all casting attempts - including Malekith, for instance, who is Loremaster (Shadow). They added this modification so the Loremaster rule keeps doing something.
I short: no.
- Curu Olannon
- Vindicated Strategist
Let´s keep the thread on BRB magic please. End times are campaign books and, until requested otherwise by the OP, not relevant to this topic.
