I faced yesterday my Wood elven friend with my Tomb Kings and we ended up in situation where I managed to score Killing Blow on his High Magic spellweaver. Then we had little argument about the ruling
At our game there were total 4 protection counter in the unit. I managed to do with same initiative step 7 wounds on the unit, 2 regular wounds on spellweaver and one killing blow on spellweaver.
I have few questions about the situation:
- When receiveing same intiative step unsaved wounds, Is the wood elven player allowed to choose which wounds he is going to save?
- Does this protection save from killing blow, as killing blow specifically states that it can only be saved with ward save.
- Does this protection save from killing blow, as killing blow doesn't cause wounds as per se.
- How does this work with multiple wounds.
During our game we decided that it wouldn't save from killing blow.
Here are the rules that I found to answer this question.
Wood Elves Armybook 8th, page 60 Ancients Protection wrote: Whenever the Wizard (or a model in tha same unit as him) suffers unsaved Wound and there are one or more protection counters next to him, remove protection counter and treat the Wound as if it had been saved.
BRB 8th page 10, Sequencing wrote: Whilst every effort has been made to make sure that the sequencing of rules is utterly clear, occasionally you'll find that two or more rules are to be resolved at the same time — normally 'at the start of the Movement phase' or similar. When this happens, and the wording is not explicit as to which rule is resolved first, then the player whose turn it is chooses the order.
BRB 8th page 72, Killing Blow wrote: If a model with the Killing Blow special rule rolls a 6 to wound in close combat, he automatically slays his opponent - regardless of the number of wounds on the victim's profile. Armour saves and regeneration saves cannot be taken against a Killing Blow. A ward save can be attempted — if passed, the ward save prevents all damage from the Killing Blow.
BRB 8th page 73, Multiple Wound wrote: Each unsaved wound inflicted by an attack with the Multiple Wounds special rule is multiplied into more than one wound
