So I was watching a game on UB and an interesting rules question came up.
If a wizard has failed a dispel attempt in a magic phase, can he use his scroll later against a different spell?
My gut says yes because he is not technically making a dispel attempt, but there were people arguing the fact that to use the dispell scroll "instead of making a dispel attempt" as the rules state, he must first be eligible to make a dispel attempt.
As far as I can see though the only time mentioned that a wizard cannot use his scroll is when fleeing (FAQ) so am I to assume because there is no mention of failed dispel attempts not allowing its use it is therefore allowed?
Thoughts?
Failed dispel attempts and dispel scrolls
Re: Failed dispel attempts and dispel scrolls
I'd say per BRB he can't use it.
If the magic item wording suggested it could be used instead of the army making a dispel attempt I'd say he was good to use it. But it strongly implies the wizard himself, to me.
it is definitely not allowed.
From the BRB faq:
Q: Can there ever be more than one attempt at dispelling a spell per
magic phase? Can a Wizard use a scroll if it isn’t allowed to make a
dispel attempt, for example the spell was cast with irresistible force
or the wizard has previously failed to dispel a spell that turn? (p35)
A: No to both questions.
Specifically mentions the case of having failed to dispel.
From the BRB faq:
Even though this FAQ is clear, I think it is worth repeating that this affects not just dispel scrolls, but all the other types as well i.e. feedback scroll.
