I had assumed you couldn't, that you reform at the start of your move range and that the only option for movement would be if it were a swift re-form with a musician, in which case you can then move.
But what if you want to move first and then re-form? I've just looked it up and the book seems to say that you must not do any further movement having already reformed, but doesn't give any requirement to not reform post movement, so long as no model moves more than twice its total movement rate.
So can you do this or have I missed something?
Can you move and reform
Re: Can you move and reform
The text in bold at the start of the Reform section on pg14 mentions 'by giving up all other movement'.
I reckon that's pretty definitive.
- definite case of reading the small print and missing the wood!
- Curu Olannon
- Vindicated Strategist
Yes you can. If you`re fast cav
