It is currently Sun Feb 16, 2020 10:23 pm
 Post subject: 8th ed 3000 pt
PostPosted: Fri Jun 11, 2010 2:02 am
Hey, so bored at work today i decided to create a 3000 point list for 8th. The point of this list is more goofy than anything else, i was attempting to see if i could fit 3 dragons into a list under the new rules. Meant to be a kind of Caledor themed mounted army and based on the possibility of Silver Helms being moved back to core. With that out of the way here's the list and my thoughts.
Lords-Four options here. All similar with different equipments.
Prince on Star dragon
Equiped with:
Vambraces of Defence, Armor of Caledor, Sword of might, additional weapon-621-20.7%
-or-
Vambraces of Defence, Armor of Caledor, GW-612-20.4%
-or-
Vambraces of Defence, Armor of Caledor, Lance-606-20.2%
-or-
Blade of Leaping Gold,Blade of Sea Gold-626-20.9%
Heroes-pretty set in stone-745-24.8%
Dragon Mage w/ Silver Wand, Guardian Phoenix-385
Dragon Mage w/ Talisman of Protection -360
Core-948-31.6%
Silver Helms x12 + FC-312
Special679-22.6%
Dragon Princex6+SB+Banner of Ellyroin-215
Dragon Princex6+SB-200
Ellyrion Reaversx6+Bows-132
So the basic idea is to quickly cover the field and charge into enemy ranks. For the most part the dragons will be in CC, even with the mages on them. If the Sword of Rhuin is allowed to be taken as a double like a basic spell both mages will have that and the one with silver wand will probably pick up a easy cast magic missile to spam. The prince will likely take center and make his way into the enemy, how fast he charges up the middle depends on which build i take. The silver helms move in tandam with the dragon princes, so hopefully both charge on the same turn allowing them to work together to cut the enemy to peices, the Reavers move out front quickly to thin out ranks/warmachine hunt, and act as a supporting flankers.
The questions i have left is whether the list is actually any good, or if it is just not fun to play against. Also still not sure which prince build to take, i'm fond of the idea of the attack maxed prince charging into the enemy. Between the 8 S4 (no armor save) Prince attacks and 6 S7 attacks from the dragon anything in front of him should be fairly beat up. Though i guess a little more survivability might help. Also do you guys feel that Ellyrion Reavers detract from the Caledor theme? Not sure if i should use them or just add more Princes?
Anyway, what do you guys think?
 Post subject: Re: 8th ed 3000 pt
PostPosted: Mon Jun 21, 2010 7:19 pm
Nice list. I love how we get to ignore all the percentage restrictions and get to keep all the expensive lords \:D/ .I'd go with bkade of leaping gold lord tbh. Are silver helms core now? Hope chaos and vampires have to do percentages, we might actually be the best race for heroes then :D .
~High Magic Lore Master of the Mage Knight Guild~
That said, Elves, being civilized, obviously have English accents.
PostPosted: Mon Jun 21, 2010 9:31 pm
Since when are Silver Helms core?
My army
PostPosted: Tue Jun 22, 2010 6:35 am
Its an assumption! Read the original post.
--- thankyou come again! ---
PostPosted: Tue Jun 22, 2010 9:28 am
im going to try this Tomorrow against beastmen. WIll see how it goes:
High Elf Prince
Armour of Calador, Vambraces of defence, Great weapon, Star Dragon: 612pts
Lords: 612pts
Noble
Dragon Armour, enchanted shield, Battle Standard, Barded Elven Steed: 137pts
(in with phoenix guard)
Noble
Great Weapon, Dragon armour, Reaver bow: 139pts
(in sea guard)
Mage
Level 2, Dispel scroll, silver wand: 165pts
Heroes (4): 441 Points
10 Elven Archers: 110pts
10 Sea lothern guard, Shields: 130pts
28 Lothern Sea Guard, Full Command, Banner of eternal flame, shields: 400pts
Core (4): 750points
14 Sword masters of Hoeth
Full command: 240pts
14 White lions of Chrace
14 Phoenix Guard
Lion Chariot: 140pts
Special (5): 1000points
Elven Repeater Bolt Thrower: 100pts
Rare (2): 200 points
PostPosted: Tue Jun 22, 2010 6:42 pm
Good but where are the eagles? Dunno if they are still as good this edition, but I sure love my feathered friends.
PostPosted: Tue Jun 22, 2010 10:33 pm
yeah i need to go back and edit that list looks like silver helms are unlikely to be core. Probably put a couple medium blocks of spears in there to replace them. then turn the reavers into DPs and use the spears+DP as hammer anvil and the dragons to cause all kinds of random hell. I like the idea of heavy attacking prince, but can't have two magic weapons so need to retool him too. I'll post a revised list in a couple days for those of you interested. Its almost all theory, it'll be a long time before i even get a test version up and running (three dragons and 20+DP will run me a pretty penny) But if anyone has the models for a list like this run it and let me know how it turns out :) Thanks guys for the feedback.
PostPosted: Wed Jun 23, 2010 4:31 pm
this isnt 6th edition anymore, cav have nothing on infantry now with stepping up and stubborn with more ranks.
PostPosted: Wed Jun 23, 2010 7:04 pm
Doesn't mean that Dragon Princes won't make good hammer units. They won't deny ranks unless they have their own, yes, but say you've got 25-30 guys going up against 25 spearmen, the flank charge from the Dragon Princes, combined with the Spears will keep your ranks either equal or higher than theirs so they won't have Steadfast.
My army
PostPosted: Fri Jun 25, 2010 8:48 am
To my knowledge whichever unit has the most ranks has steadfast. So you don't just add the ranks you have. (ie, enemy infantry with 6 ranks, my spears with 5 and my dp with 2 results in steadfast for them, not me).The main way to deny a infantry block steadfast is to do enough casualties to reduce theirs below yours. So mainly i'd try to hit each block with enough force to shatter their numbers quickly.
