A proper SISTER STAR.
Re: A proper SISTER STAR.
What's the benefit of one big sword block rather than two or three smaller ones (other than BotWD, although in smaller ones they'd have to play BotWD bingo ).
Here's a few reasons why to take a bigger rather than smaller block:Ferny wrote:What's the benefit of one big sword block rather than two or three smaller ones (other than BotWD, although in smaller ones they'd have to play BotWD bingo ).
1. Point denial. Small sword Blocks tend to die - fast. 2 units of 10 - if you lose 10 in one unit, you lose half points. if you lose 10 out of 20 man big unit, you lose zero points.
2. Fighting other big units. Small sword units will get worn Down too quickly.
3. Rank bonus (and possible steadfast)
4. Easier to buff (only one unit, does not require bubble buff)
Just off my head - hope it helped
Meta lists dont have named characters. Meta is something like must have in specific army, or popular deployment of most usable/killy units. Teclis not fit to any meta.Perfection is more of just my goal. I think that old I listed in there was pretty dang close. A perfect list is a list that has a solid chance against all list, especially meta list. I am really not enjoying the power level of my white lion's against a lot of dark elf builds.
Conclusions in other thread concerning BS shooting are quite opposite to your ideas. My experience with HE shooting share other players opinion in this forum, that BS alone can`t be decisive. It is not matter of pure math - it is matter of deployment, terrain, enemy troop selection and so on. BS shooting can be only supportive - you can make pure shooting army, but i doubt that it will be competitive.I know I'm being a little obnoxious posting my build everywhere but I wouldn't be so zealous if people actually gave it a try. It's well rounded with the ability to fight any army and it's unique. You can find the full build in the army section but in here I am going to go over how to use BS shooting to decimate just about ANY army.
Comments on your armylists.
Teclis centered, shooting/deatstar combo. All of them are quite the same. They share weaknesses and strenghts.
Pros: Normal combos, non unique - so most of the players know how do you plan to use it(it can be Con - enemy will be aware how thouse units working). Deathstar. Strong shooting element(not stron enough to decimate ANY army - i have own experiences with HE BS shooting, and i disagree that you decimate ANY army).
Cons: Single character centered(Teclis) and general as heavy spell caster. Deathstar. Support very nicely done, optimal - but for optimal army list - not with this specialized army list. Heroes are not protecting Teclis from harm - and are very soft, making them also very nice target in combat.
Notes on Deathstars - usually, they need to be supported by some hitty elements. Your armies lack such - so in case of trouble, deathstar can be placed into undesirable combat and grind down using numbers or high A/model type of unit. You dont have support to add considerable CR to the fight and break such unfavourable combat, relieving your deathstar. Deathstars are quite big, so experience is needed to position them to combat, avoiding redirection and other nastiness.
Most of your lists are exposing poorly fighter - Teclis to be at the front rank of Deathstar. There are few tricks how to kill precious characters right in their deadly retinues. Your Teclis is not save. And he will be targetter - it is 20% of your entire points. And general bonus. Juicy target.
Can you make some armylist not based on Teclis, but on normal, not named characters? Maybe you can wrote down some more deployable armylist that can be heavilly tested in tournament environement?
P.S. topic was about sister star. I`m pretty sure, that i saw only one army ist with SoA. So, where are thouse stars? Whole discussion is offtop?
Guys Enchanted Blades doesn't give ranged attack armor piercing I found out. So the sister star is a no go. Sad, I played a lot of games incorrectly that means. Without -3 to armor the build is heavily hampered. The Swordmaster build was kind of flop. White Lion's and Phoenix and vastly superior ill be sticking to them. The last build was kind of an experiment. I would say it didn't really work that well. This is what I am running now. I don't bother with buffing my archers anymore because no armor pen means it doesn't do well. I just cast final transmutation.
High Elf Perfection 2500
LORDS AND HEROES 605
Teclis 450
-Scroll of Hoeth
-Staff of Lileath
-Crown of Saphery
-Lore of Life: Flesh to Stone
-Lore of Light: Speed of Battle
-Lore of Death: Doom and Darkness
-Lore of Fire: Flamming Sword of Ruin
-Lore of Heavens: Harmonic Convergence
-Lore of Shadow: Okkam's Mindrazor
-Lore of Beast: The Amber Spear
-Lore of Metal: Final Tansmutation
Noble (Stryfe) 155
-battle standard bearer
-heavy armor
-lion cloak
-halbred
-Charmed Shield
-Reaver Bow
-Potion of Strength
CORE 625
22 Archers 250
-full command
15 Silver Helms 375
-full command
SPECIAL 730
50 White Lions 730
-full command
-Banner of the World Dragon
RARE 480
Frostheart Phoenix 240
1 Great Eagle 60
-swiftsense
I will probably split the white lion's into a PG and white lions units like I had originaly. Also I found out Ive been charging my self 25 points then I should like a retard for Teclis. Which was nice as I get 25 points to play with. The archer buffing was doing pretty good but then I ran into a double stank list with 10 mother fucking demigryph and learned that enchanted doesn't give AP to ranged attacks. Therefore I couldn't do anything to his list and got massacred. Oh well... I am still rocking Mr. T tho. He is just so much more exciting than a shadow mage.
Teclis 450
-Scroll of Hoeth
-Staff of Lileath
-Crown of Saphery
Noble (Stryfe) 155
-heavy armor
-lion cloak
-halbred
-Charmed Shield
-Reaver Bow
-Potion of Strength
CORE 625
22 Archers 250
-full command
15 Silver Helms 375
-full command
SPECIAL 730
50 White Lions 730
-full command
RARE 480
1 Great Eagle 60
-swiftsense
I think I'm going to have to disagree here. Armour piercing normally only works in close combat (though it can work on shooting as demonstrated by the line "or shots fired"). But the wording of enchanted blades specifically mentions that "all attacks count as armour piercing". And this is after having mentioned all close combat and shooting attacks being all attacks.Drakova wrote:Enchanted Blades doesn't give ranged attack armor piercing I found out
Therefore, normal armour piercing doesn't works for shooting, enchanted blades does.
As I really want to run enchanted with a range army ill go to the store and debate this with the people I play with. I think your are correct and they falsely dashed my hopes.
biggest problem with this list is that 35 sisters cost £120, the average room price for a very nice hotel for a weekend away with the Mrs, or two nights in a B&B with the Mrs!
or in my case, 4 starter armies for infinity
I dont think, that they have neccesary models for lists presented here Proxies and Mathammer are not problematic at all.
Is that they are still quite soft in melee. One proper cav charge with HtH character in it and i dont see sister deathstar winning anything. Also, with the list above, there is no sisterstar - but only 3 quite big units and 2 unridden monsters - perfect army for either shooty/artillery army like Dwarf/Empire or HtH army with lots of chaff/redirectors.biggest problem with this list is that 35 sisters
Drakova wrote:Sackree wrote:One dwellers below/ final transmutation and half of that "high elf perfection" is gone. Far too many points in one basket for a unit the opponent never has to engage.
In theory Ill be able to punish anyone who is spamming dwellers because that means they are not rushing into combat. I got a lot of shooting myself. While those spells are scary I do got a chance to remove it from the game and then they would be screwed. Yeah it's a problem but I don't think this army would auto lose if 1 dwellers went of and 30 swordmasters died. There is a good chance ill shut down any spell like that with Teclis untill it's to late. Str 1 Teclis, dwellers always was a problem even before I made a 60 man unit. It hasn't gotten through yet but there will be that game where it gets IF and Teclis dies and Ill lose like turn 2. I think my list is just as vulnerable to dwellers before because of Teclis. Well I use to out range 24 usually with Mr. T since I just need to buff my own so I can see the swordmasters being range every turn to get blasted by dwellers.
And doesn't Teclis have that forget scroll anyway? My friends don't allow me to play with Teclis, I haven't even been allowed to try him out with the new rules
Besides, you should change the topic of this whole thread to how to abuse Teclis to the max, because it seems to me that the core focus of your army is how to maximize your magic fases. You could substitude any of your units, take different spells on teclis that augment these units and start a whole new thread
It's a nice find though, makes me want to whack my friends with him
edit: whoops you did mention the scroll, I was just to lazy to read properly
I liked the concept of your shooting list.
