Hey guys !
The Lothern Sea Helm allow you to make a free reform if you pass a leadership test after being successfully charged. Does that mean that if you are getting charged from the flank or from the rear, you can change where your current unit is looking at ?
Also, does anyone use this character as Bsb ?
Lothern Sea Helm
Lothern Sea Helm
[img]http://i24.photobucket.com/albums/c14/Selvhan/Signature.jpg[/img]
With tall lance held to our foe's throat,
Cold fury guiding our aim,
We are death upon the wind.
Re: Lothern Sea Helm
You can change your faceing after the charge but you must maintain the same number of modles in contact. I use him but mounted on a skycutter. Cannot find a good use for him in a unit as his ability is normally only used when you make a mistake.
You're not allowed to remove models from base contact, but you can add new ones, assuming the enemy is wide enough.First Strike wrote:You can change your faceing after the charge but you must maintain the same number of modles in contact. I use him but mounted on a skycutter. Cannot find a good use for him in a unit as his ability is normally only used when you make a mistake.
I've found his best use in a unit of swordmasters runnign long and thin 2x 7 or 3x 7, as allows the swordmasters to be present frontline and not have to worry about flankers. The opportunity lost in his namesake unit by not allowing a stand and shoot and reform still makes me cry inside
