Tempest wrote:If it was used that way though, surely it wouldn't help with champions in units as they all have the same initiative so all strike their blows at the same time. Which means they would all wound at the same time, so the champions wound won't have happened before the rest of the models attacking (and thereby jinking him) and you opponent would be making all the saves together.
As far as I am aware you can't choose which wounds are applied to the target first from hits from models with the same I, there isn't some sub layer timing sequence or something (unless I have missed it in the rulebook), so everything happens at once.
Characters on the other hand have higher I, so could technically hit first to get the jink in.
Actually, if you reread the BRB, you will see that tecnically attacks are done one at a time. However to speed up the game we all roll the dice in batches.
PapaElf wrote:Any additional wounds on that specific model(s) (IF they count) would have to come from a friendly model in base to base contact with the same wounded model, and would have to be specifically targeted. Against big base targets maybe, but if all this is true, it's one hell of an undercosted item.
Agreed, this item is usefull only against large base targets like giants and hydras. The reroll of sucessful saves is forced on only one model (the one wounded by the ToL bearer) so it's useless against standard based units or at best of very scarce utility.
As for the wording controversy I'll explain in more detail how I interpret this.
Talisman of Loec
This item is used at the start of any Close Combat phase. The bearer may re-roll all rolls to hit and to wound until the end of the phase. Any model wounded by his attacks this phase must re-roll any successful saves of any kind.
I've pointed out the part that I think is the most important. Any model wounded by the attacks of the bearer of ToL must re-roll ANY sucessful saves of any kind. If said model is attacked by more then one model it is conceivable that some of those attacks will wound as well. So the attacked model has to roll saves not only for the wounds dealt by the ToL bearer but also for the wounds dealt by other models that attack it. And since the ToL says that the model has to re-roll ANY sucessful saves it's clear to me that he has to re-roll all sucessful saves regardless of origin. Had ToL a wording that said that the model has to re-roll saves on wounds dealt by the ToL bearer the situation would be different.
So to sum it up, to me the wording is very clear. The model should re-roll all saves on wounds it suffers that combat phase, regardless of origin of said wounds.
