These ones.
The azure host
- Very Helpful Elf
Re: The azure host
Ow, I know the world is diverse enough that you'll find anything somewhere. And that in most cases someone has managed to come up with a dark and powerful myth about it. It was mainly just my feeling. Of course, even if puffins are cute and cuddly they could very well serve as a unit symbol. After all, it only brings more shame to your enemy if they get beaten by a cute lil bird.Vermis wrote: Mine'll be covered in hearts, so I can't entirely get behind you.
The metallic paints from GW are still better then others. For the rest, shopping at GW is mainly about convenience, not quality.Vermis wrote:Graduating on from most GW hobby products is rarely a bad move
It's probably hard to find a tub of brake fluid large enough to fit a whole car...Vermis wrote:I guess they have to get it right because cars are a bit more trouble to strip or fix than minis.
Re: The azure host
I have to disagree with both of you, GW products are relatively ok, but there's much better stuff out there. The only citadel product I really recommend are the pliers. Scalecolor (link) which are about the same price as citadel, are richer in pigment and I couldn't recommend them enough. They also have a color that's called "black metal" that is just gorgeous.Prince of Spires wrote:The metallic paints from GW are still better then others. For the rest, shopping at GW is mainly about convenience, not quality.Vermis wrote:Graduating on from most GW hobby products is rarely a bad move
Well, if you look closely the bird on th shield of my Selafyn mini is painted like a Puffin, I thought it more like a local fauna thing. Prince Laurendiel (which is the name I chose for him) comes from a small island in the northern part of Ulthuan where puffins live... I wanted to give him a small unit to follow him aroud !Prince of Spires wrote:Ow, I know the world is diverse enough that you'll find anything somewhere. And that in most cases someone has managed to come up with a dark and powerful myth about it. It was mainly just my feeling. Of course, even if puffins are cute and cuddly they could very well serve as a unit symbol. After all, it only brings more shame to your enemy if they get beaten by a cute lil bird.Vermis wrote:Mine'll be covered in hearts, so I can't entirely get behind you.
Re: The azure host
That's definitely a good enough reason for the puffin bannerceeprime wrote:Prince Laurendiel (which is the name I chose for him) comes from a small island in the northern part of Ulthuan where puffins live... I wanted to give him a small unit to follow him aroud !
Re: The azure host
Smaller heater shield, compared to the taller spearelf type?Shannar, Sealord wrote:These ones.
Well, they don't have all the Lileath imagery, but Eccentric Miniatures sells plastic sprues of similar shields. Can't say how they'd directly compare, or how the business is to order from. (Almost ordered from them a couple of times. I don't think much of their minis, but their bits and accessories are very tempting.)
I wonder how easy it'd be to stick on a crescent moon with some putty and a couple of plastic or metal tubes with different diameters and sharpened edges...
I think I came on a bit strong there! I like it because to us, it's a cute, clowny little bird, but to these tough, haughty elves it's not. It suggests a different culture that isn't just all dragons and phoenixes and eagles - the obviously tough, grr-aargh creatures.Prince of Spires wrote: Ow, I know the world is diverse enough that you'll find anything somewhere. And that in most cases someone has managed to come up with a dark and powerful myth about it. It was mainly just my feeling. Of course, even if puffins are cute and cuddly they could very well serve as a unit symbol. After all, it only brings more shame to your enemy if they get beaten by a cute lil bird.
And if I can say so, a more subtle culture than the WoW-style... how to put it diplomatically... 'lack of restraint' that AoS is carrying on with.
Rarely a bad move. As in, most of the time it's a good move. Sorry, maybe it doesn't translate well.ceeprime wrote: I have to disagree with both of you, GW products are relatively ok, but there's much better stuff out there.
Which is the same reason as Værøy. Nice!Well, if you look closely the bird on th shield of my Selafyn mini is painted like a Puffin, I thought it more like a local fauna thing. Prince Laurendiel (which is the name I chose for him) comes from a small island in the northern part of Ulthuan where puffins live... I wanted to give him a small unit to follow him aroud !
