It is currently Sun Feb 16, 2020 11:08 pm
 Post subject: My 8th edition army
PostPosted: Sat May 29, 2010 7:26 pm
Bond... James Bond
The idea behind the army is to thin down enemies with magic and shooting and than fight them of in combat.
Archmage @ 340
Staff of Sorcery, Ring of Fury, L4
Noble @ 195
Great Eagle
Dragon Armour, Lance, Enchanted Shield, Reaver Bow
25 Spearmen @ 250 pts
FC
FC
10 Archers @ 110 pts
24 Swordmasters @ 445
FC, Standard of Balance, Gem of Courage
5 RBT @ 500
1 GE @ 50
CHARACTERS: 535 pts - 23,78%
CORE: 720 pts - 32%
SPECIAL: 445 pts - 19,78%
RARE: 550 pts - 24,44%
TOTAL: 2250 pts
 Post subject: Re: My 8th edition army
PostPosted: Sat May 29, 2010 8:02 pm
Maybe a second eagle instead of the fifth RBT? That way you have another redirect unit to help slow down the line more.
PostPosted: Sat May 29, 2010 8:46 pm
Obviously all this is speculation until the book is out. However, going on rumors.
The staff of sorcery looks like it will be very good in the new edition, so that is a good choice. I'm not sure about ring of fury, depends on the rules for bound spells. I'm actually not sure the level 4 upgrade is worth the 35 points. It will only give +1 to cast and an extra spell (possibly, don't think there are many rumors on spell generation yet). It won't be giving you extra power dice anymore. The noble seems good, none of the rumors affect him much as far as I can tell, except his eagle will have crushing attacks or something...
I guess you are going on 25% core. If so, that is a bit much. LSG seem to be the best choice for us next edition. I would consider taking around 30-40 LSG in a block, making for a very powerful, and stubborn, centre for your line. That is only around 400-500 points, so take another smaller unit of LSG, or archers, to make up to 25%. It is immpossible to tell if command is useful or not, musicians seem mandatory though.
24 swordmaster, 3x8? or something else? if you are going 8 wide you might as well make it 10 and get stubborn. We'd just better hope that they can still strike first most of the time, or we could be in trouble. Standard of balance and gem of courage seem like decent choices, though I'm not sure that the fear and terror immunity are as useful now that autobreaking is gone.
I would drop a bolt thrower for another couple of great eagles, you could have 15 GEs if you where completely eagle crazy, but I don't think that is a good idea :lol:. 4 RBT is a lot though, and 2 eagles may be needed to slow the enemy down more, unless marchblocking is changed completely, in which case eagles may become useless...
We shall see
Edit: great minds think alike bolt thrower :P
Furion wrote:
PostPosted: Mon May 31, 2010 6:57 am
Bond... James Bond
As far as core section is concerned I just took what would look cool on the battlefield and added a unit of swordmasters inbetween.
I have been pondering about droping an RBT and taking 2 more GE but somehow I do not see the point with enemies being able to march block them unless I pass a Ld test and at the same time they will not be doing as much march blocking as before due to the same rule.
On the other hand additional RBT's will be vital to thin down approaching enemies.
I had a practice game last night and 5 RBT at a single target backed with Curse is a horrible experience(17 Temple Guard on turn 1, 16 Saurus on turn 2 and 9 Cold one Ridders on turn 3).
As it stands our Lore with low casting values it amazing. A level 4 can hope to cast any of our spells with 2 dice while using 3 is an almost sure cast.
PostPosted: Mon May 31, 2010 7:37 am
i may be wrong but isn't there a rumor that says you can only have 2 of the same rare, 3 in a large game?
PostPosted: Mon May 31, 2010 7:51 am
Bond... James Bond
You are right but that rule does not include HE who have a special rule called Elite Army which allows them to take what ever they want within the percentage.
PostPosted: Mon May 31, 2010 10:36 am
I don't believe I'm saying this but as it stands 2 or 3 rank WL mght be the best infantry choice we have. Units of 12/14 might allow us to have a long enough battleline of stubborn troops to make lapping around our flanks considerably harder. I don't think the quasi gunline approach might work, espcially with the mobility of infantry allowing the defending player to easily screen or protect his valuable units, and also with the increased charge ranges you might not get as many shooting phases as you would in the current game.
that said, the army would look great. I used something like that in 6th for a bit and it was great fun even if swords werent very good at the time.
PostPosted: Mon May 31, 2010 2:33 pm
I think we'll see a lot of lists with just an archmage for magic. I think it should work out well. However this army will really suffer against big armies. How are you going to protect your bolt throwers??
Defender of Ulthuan
