It is currently Thu Apr 02, 2020 1:10 pm
PostPosted: Fri May 21, 2010 2:43 am
Heroes:
Noble with Sword of Might, Dragon Armour, Barded Elven Steed, Shield- 124 points
Core:
10 Archers- 110 points
Special:
12 Swordmasters- 180 points
8 White Lions- 120 points
Lion Chariot of Chrace- 140 points
5 Dragon Princes (Standard bearer)- 170 points
Rare:
Repeater Bolt Thrower- 100 points
Great Eagle- 50 points
Total: 994 points
This is the finalised army list I think that I'll take, tell me what you think :)
PostPosted: Fri May 21, 2010 3:08 am
Hello there and welcome to Ulthuan!
I think you should definiitely drop the command from the DPs. Give your Noble Helmf of Fortune and Sword of Might, drop the lance, too.
If you have the models, drop the command off of the Swordies for two more to bring them up to twelve. Alternatively, you could keep the champion and give him Talisman of Loec.
Everything else is fine. I could suggest brining a little bit more shooting to help out the lone RBT but since you're new to the army I say just go out there and enjoy playing your new High Elves!
Goodluck on the field of battle.
PostPosted: Fri May 21, 2010 1:33 pm
I think spending 21% of your army on a slow ranked infantry unit with insignificant combat capability and no leadership protection is a huge mistake. Stick with 110 pt archers for core, especially at this size game.
Full command on just 5 DPs is not worthwhile. The banner can be, but only if you buy a magic banner. I would absolutely rather have a 6th guy instead of the champion and musician.
I don't think full command on 10 Swordmasters makes sense either. Again, maybe if you add magic items or more numbers, but not without those. 7-9 with nothing is just as useful as what you listed, but costs less and gives up less VPs when killed.
PostPosted: Sat May 22, 2010 4:14 am
Yeah I might get rid of the spearman for archers, i mainly wanted spearmen to be the anchor of the force; but now that i think about it opponents can just tie them up with a throw away unit and they'll be wasted. If I get rid of them what should i get instead; i was thinking maybe a unit of 5 white lions (if i can afford it).
Thanks for the tips regarding dragon princes/sword masters; will probably make those changes
PostPosted: Sat May 22, 2010 5:38 am
5 White Lions can't really do much, unfortunately. They have no fear protection and if you give them a banner to do so, they will be killed off rather quickly and you will be giving away free victory points.
Get the archers and a few more Sword swinging dudes, you can slowly start building up to a larger army list by beefing up that unit.
PostPosted: Mon May 31, 2010 11:21 pm
Give your sword masters the Banner of Balance which makes them Immune to psychology. The SM's can hide behind the archers if you are up against a shooty list eg: DE's or WE's or a Gun line.
2008-2013 Wins:Draws:Losses
