Hey guys, you may have seen my post before about a 2250 list that would be effective against most opponents. Well I've updated the list, and now I want to know your thoughts!
Archmage – 330
General
Level 4
Silver Wand
Ring of Fury
Dispel Scroll
Noble – 128
Armour of Caledor
Talisman of Loec
Great Weapon
Mage – 185
Level 2
The Seerstaff of Saphery
Dispel Scroll
(20) Spearmen - 225
Command
War Banner
(10) Archers – 110
Lion Chariot of Chrace - 140
(7) Sword Masters of Hoeth – 105
(5) Shadow Warriors – 80
(12) White Lions of Chrace – 255
Command
Standard of Balance
(5) Dragon Princes – 250
Command
Banner of Sorcery
Great Eagle - 50
Great Eagle - 50
Repeater Bolt Thrower - 100
Repeater Bolt Thrower – 100
Total: 2248
Let me know your thoughts, as well as where to put characters. Thanks for the help!
Revised 2250 Take all comers list!
Re: Revised 2250 Take all comers list!
i'm not sure what you plan to do with your noble... make him BSB and he might be a little usefull at least ^^
2250p army 2010 results
Massacres: 4
Solid victory: 2
minor losses: 1
Massacred: 1
Massacres: 4
Solid victory: 2
minor losses: 1
Massacred: 1
Your AM should go in either your lions or spears. If you put him in your spears I'd say you should use your noble as a bodyguard against a suicide charge to pick him off. That said, he should be a BSB as well.
I'd be more comfortable with the Lion Standard on the spears rather than the war banner. That failed terror test and/or auto break from fear causers will happen and will hurt when it does!
Noble should be BSB (stated already).
Other than that a good balanced Archmage lead army.
Cheers.
Cheers.
What Tirrith said.
- Flame of the Asuryan
I do not agree in that. Spears need warbanner. They are for static combat resolution. Lion Banner is better reserved for your hammer, unless the spears are really a major part of your army.
Maybe to give amulet of light to DP?
Would that hammer be DP's then? I can see the virtue in not rolling that 1-in-6 for them to fail a charge. There are other solutions though, for instance a Ld10 General or the Dragonhorn. I agree that War Banner is a reasonable pick for Spears but I (like many) tend to run my BSB in mine. Losing combat by 1 or 2 isn't such a problem. Compared to failing a Terror test for example.Flame of the Asuryan wrote:I do not agree in that. Spears need warbanner. They are for static combat resolution. Lion Banner is better reserved for your hammer, unless the spears are really a major part of your army.
