Hey guys come up with this 2k list, wandering if its powerful, competative and any general improvements. I want a cheesy comp list which with skill will play well against most people
Prince Dragon Armour Elven Steed Sheild
Vambraces of Defence lance ROF
BSB barded steed, lance, sheild, dragon armor, battle banner
mage, 2 dispel scrolls
10 archers
10 archers
8 dragon princes with full command and standard of balance
2 eagles
bolt thrower
SM with full command
30 spears lion standard and full command
lion chariot
So how does this do u reckon and what improvements
General Plan is for spears to hold centre, Prince BSB and princes and chariot to charge across flank and break units left right and centre, I could give lord lvl 1 for sheild. while i use mage for watever he gets and/or Drain magic and scrolls :p Eagles stop march and shooting takes damage.
2k list
Re: 2k list
Hello !
Your magic defence is weak at 2k. You should add a second mage, and take the lvl2 for the two. Or if you want have just a defence magic, you should add the lvl1 on your lord with the gemm of hoeth.
The unit of 30 spearmen is very big, you should take 2 units of 15, or units of 20 and 10.
The lion chariot is expensively, and I prefer taking the tiranoc chariot, but it's a personal choice.
It's just my opinion.
How many ? :dSM with full command
Re: 2k list
The Lion chariot in my opinion is a better breaker as it gets their better and has better attacks, However i could try the tyranoc as you get basically 2 for the same points, the lvl one is really only for 1st turn, and maybe 2nd turn defense as i aim to be in combat 2nd turn. But if i go first. The spears are there to be a semi anvil handing out loads of attacks and taking some damage in return and its seven swords.
Re: 2k list
If you can find 100pts for the following, you have a magic phase:
Swap Ring of Fury for Radiant Gem
Upgrade Mage to Lvl2 and swap Seerstaff for one scroll
Banner of Sorcery
Banner of Sorcery
Re: 2k list
Updated list based on some recomendations.
Prince Dragon Armour Barded Elven Steed Sheild
Vambraces of Defence lance Radient Gem
Battle Standard Bearer barded steed lance dragon armour
sheild Battle Banner
Mage 100 dispel scroll level 2 seerstaff
10 Archers
10 Archers
8 Dragon Princes Full Command banner of ellyrion
2 Eagles
Bolt thrower
Ellyrion Chariot
ellyrion chariot
Ellyrion Chariot
7 dragon princes Full Command banner of sorcery
any ideas of this list. Do you guys reckon it will do well.
10 Archers
10 Archers
2 Eagles
Bolt thrower
Ellyrion Chariot
ellyrion chariot
Ellyrion Chariot
