Updating the site - ALL USERS READ
- Burning Sun
- Fire and Faith
THIS IS IMPORTANT
OK, this is an announcement about changes to the site, and this time they're MAJOR changes.
For those keeping up with the blog* this is just a continuation of what I've been posting over there. For the rest of you, I did tell you the blog would continue to be updated.
As many of you will have noticed, the site has been falling apart at the seams for a little while. We've had several crashes, including the one that wiped out turn 20 of the campaign. Now, as Ulthuan/Asur has a history of these, it didn't come as the greatest surprise, but this time, we've decided to jump ship before it sinks. As a result, Ulthuan will be changing.
Voodoomaster and I have spent the last couple of days installing and getting a new Library working. It's based on a piece of software we've had installed for a while on the site. You won't have noticed it, because for most users all it does is re-direct you from http://www.ulthuan.net to /forum/portal.php, but it is capable of so much more. I was trying for a long time to get it integrated with the forums, but have now scrapped this and it's working on it's own. So, we have a new portal and library. The library requires a lot of the articles input again, I didn't realised when I started just how much is in there.
So, that's the explanation (See also the blog, although you may not want to do that yet), this is the shorter version.
We will be upgrading the site to phpBB3
We will be installing some new software to go with these changes based on a recurring theme. You'll find out what when it's working.
We have already installed a new library and home page. (You just can't see it yet, but it does work) (Also, the homepage is now part of the library, this is an attempt to make the library more visible)
What does this mean for you? Well several things. We will be archiving this forum. We will be closing the forum and setting it to read only. To do this, the site will have to be down for probably a few days. We have no idea just how long the upgrade to phpbb3 will take for the forum, (although I have a feeling Nag may tell me), but better I overestimate now and you're all happy.
Also, only posts that have been updated in the last month will be transferred to the new forums. If there is anything that's important that we save for updating, please PM me with a link and reason, and I'll consider it. Also, please PM me and not any of the other Lores.
The basic plan is a fresh start, hence only taking a month's worth of posts. Also, I don't know if PMs will transfer, although you'll still have access to the old one's once we're finished (I repeat here that we will continue to have access to everything here, you just won't be able to add new stuff). User accounts should all go with us. Other stuff... ask and I'll see.
Questions and comments welcome as always.
*Blog: http://ulthuan.livejournal.com
EDIT - Damn, can't get big red text to appear either big or red on the portal.
[size=90]Ex-Loremaster, despite what some of the profile may say, I can't edit it any more. Contact one of the others for issues.
Whaia e koe ki te iti kahurangi; ki te tuohu koe, me maunga teitei - Maori Proverb
(Seek the treasure you value most dearly: if you bow your head, let it be to a lofty mountain)[/size]
Re: Updating the site - ALL USERS READ
It all depends on the amount of data you're transferring. For a site with half the amount of posts, it took less than an hour to do the upgrade. But I know you've had issues in the past where it got estimated to several days. It's hard to say, but it shouldn't take too longBurning Sun wrote:We have no idea just how long the upgrade to phpbb3 will take for the forum, (although I have a feeling Nag may tell me), but better I overestimate now and you're all happy.
~ Naggie
[list][url=http://www.asrai.org][img]http://www.asrai.org/siggie2.png[/img][/url][/list]
Well, one thing I've noticed with phpbb3 forums is that the posts tend to use much more space and generally has more wasted space on the monitor instead of posts. I hope you guys can fix it in a way that will make it close to the current layout...
[b]Tholwë the Enforcer[/b]
Defenders of Ulthuan Mapmaker
[img]http://www.abload.de/img/cs6lk2j.gif[/img][img]http://www.abload.de/img/bg6fohh.gif[/img][img]http://www.abload.de/img/adjjyj.gif[/img]
[quote="harry"]fight in three ranks, eighteen ranks deep.[/quote]
Allerion:
[img]http://www.abload.de/img/bg11hc95.gif[/img][img]http://www.abload.de/img/lw6ecde.gif[/img][img]http://www.abload.de/img/mora3q5k.gif[/img]
[i]Dread Lord Zakhital Goremane the Incompetent, 181 kills 5/22/11
[color=red][b]Vaul's Vengeful Villain[/b][/color]
[url=http://img3.abload.de/img/paraicamonueiq.jpg]Paraicamon, I choose you![/url][/i]
- Burning Sun
- Fire and Faith
Yeah, that. Older posts will be read-only on the existing forums, and we'll be getting "new" forums with everything from the last month, plus important stuff.
Sweet, does this mean we'll get ignore lists?
[size=75][b]Azreghai Wormkin, Ghöl of the North, Eater of the Dead, Plague-Wight of Onogal[/b]
30/4/5 : 387 kills
[i]Maggot Fetus, rapture of the conqueror worm,
Blackest Venom, the ghost in the carcass womb
Teeth like thorns, carrier of plague and filth
Spine crawler, plague-bearing virus-child[/size][/i]
30/4/5 : 387 kills
- Burning Sun
- Fire and Faith
I think the answer to that one will have to be "no", but with reservations. We're trying to maintain the spirit and feel of Ulthuan, and with that needs to come a lot of the stuff we're doing now. Allowing you to ignore each other by automation can generate feelings of animosity and ill-will, if you're ignoring a member and they ask you a direct question for example. If you're doing it manually, you're being rude, but if you never saw the post in the first place? Makes our live harder, so we will be considering each and every new feature of phpBB3 that we use.
- Alfginnar Oakenshield
You're a nice chap, eh ?Raukov wrote:Sweet, does this mean we'll get ignore lists?
Will post counts be transferred? Not that it matters to me of course...
[img]http://www.abload.de/img/defender37qyn.jpg[/img]
[img]http://www.abload.de/img/bg10dufl.gif[/img][img]http://www.abload.de/img/vacfvv.gif[/img][img]http://www.abload.de/img/lw6ecde.gif[/img]
[i]Vaulkhar Caladain Stormbreaker[/i]
- grantmepower
- Burning Sun
- Fire and Faith
You're not the first one to suggest that. It will be taken into consideration.
- Prince_Asuryan
- Giantslayer
I worked hard for mineAlfginnar Oakenshield wrote: Will post counts be transferred? Not that it matters to me of course...
Whatever, I don't mind if they stay or go - I leave it to the Lore's and their infinite wisdom
I'd like that too!grantmepower wrote:In fact, it would be nice if they were deleted completely.
- grantmepower
- Burning Sun
- Fire and Faith
Hmm,
Well given the vocal support for this, it's very much on the table, but there are two things worth considering still:
We are only keeping the last months worth of posts, the easiest way for me to do this is using the forum system, which may well reduce post counts accordingly.
Also, if you think we should keep them, speak up! I can only listen to people that tell me things.
- Prince_Asuryan
- Giantslayer
Just to be awkward. I feel that the post counts generally give a good indication to the new members of the forum who are reliable and experienced members of the boards, seen as OT doesn't effect it.Burning Sun wrote: Also, if you think we should keep them, speak up! I can only listen to people that tell me things.
That said, as I have stated, I'm not overtly bothered about it, but I like having a big post count
I'd also comment on the loss of the OT forum. I rarely pot there, and I wouldn't miss it. But I think it forms a big part of the community of the site, and losing it would be a mistake.
- Burning Sun
- Fire and Faith
Lets be clear. The OT forum is not going anywhere. My last post was unclear, that we are considering getting rid of post counts.Prince_Asuryan wrote:I'd also comment on the loss of the OT forum. I rarely pot there, and I wouldn't miss it. But I think it forms a big part of the community of the site, and losing it would be a mistake.
I suspect (but don't know) that everyone's post counts will be seriously reduced when I delete thousands of threads for the new site. (and let me be equally clear here that a copy will be made, then thousands of threads deleted from the copy, then the copy will be used to make the new site, without deleting the originals)
I don't see the big deal with the post count. It really doesn't matter that much does it, and deleting them just seems like one more thing to do even if it is a trivial step. I don't see why they need to disappear as they're pretty meaningless as is. They're just kind of there. Do people really pay attention them that much that they feel it has a negative impact on the community?
[img]http://www.abload.de/img/lmgwwzj.gif[/img][img]http://www.abload.de/img/bg3-2iu34.gif[/img][img]http://www.abload.de/img/cw69lwp.gif[/img]
[img]http://www.abload.de/img/lodek0wn.gif[/img][img]http://www.abload.de/img/arhav13f.gif[/img][img]http://www.abload.de/img/campaignpegl.gif[/img]
ANDRUILLIUS IS A GREAT AND NOBLE MEMBER OF THIS BOARD. HE IS GOODNESS. HE IS LIGHT.
- Burning Sun
- Fire and Faith
Personally I tend to use post counts to tell whether or not a person is a well established member of the community. I have a simple test, if they have more posts than me, I should probably know who they are...Prince Elileth wrote:Do people really pay attention them that much that they feel it has a negative impact on the community?
That says about as much about my post count as anyone else's though.
Post count is a rough measure of user's activity. Whether this activity is useful or not is another, and hard to judge thing.
I understand that there are people who might spam the forum to get a high post count, though I have never seen that. But I expect, that spamming the forum will get boring once the spammer gets over 100 or 200. Above these numbers, changes are less visible and less rewarding
I have personally only really looked for post count during HotW, where, as a HQ member, I wanted to know my soldiers. (An account created in 2005 and 13 posts meant that this person will probably not cooperate.) And, of course, I spent some time wondering, why does Leth's post count not change
I think that it is better to leave them as they are (with OT posts not counted). For newcomers, post count is a way to guess who is established member of community.
(I wonder, how low will my post count go, once all the threads from Reik forum get deleted )
[img]http://www.abload.de/img/lw6ecde.gif[/img][img]http://www.abload.de/img/bg9ismp.gif[/img][img]http://www.abload.de/img/p4ipaw.gif[/img]
Gaurbund Angecthelion, retired Quartermaster of Corsairs of Obsidian Citadel
I agree, that said I understand why one would want them gone, however I tihnk they could be replaced by ranks ala Roundtable where each person obtains a rank after a certain number of posts, this number of posts however is unknown to all the members. Otherwise I would prefer if we kept the post counts.Prince_Asuryan wrote:Just to be awkward. I feel that the post counts generally give a good indication to the new members of the forum who are reliable and experienced members of the boards, seen as OT doesn't effect it.Burning Sun wrote: Also, if you think we should keep them, speak up! I can only listen to people that tell me things.
Ambassador of the [url=http://www.roundtable-bretonnia.org]Roundtable of Bretonnia[/url]
[quote="EricJ"]You're all (well.. except Raneth) forgetting the age-old dogma: on the internet, all men are men, all women are men, and all children are the FBI.[/quote]
"Brute force with care"
-Luna Guardian
-Luna Guardian
- Prince_Asuryan
- Giantslayer
Ranks, while a nice idea, just make people spam. I think it's the reason we don't have them already. People get them awarded by the lores as something special - an idea I like.Uther Di Asturien wrote:I agree, that said I understand why one would want them gone, however I tihnk they could be replaced by ranks ala Roundtable where each person obtains a rank after a certain number of posts, this number of posts however is unknown to all the members. Otherwise I would prefer if we kept the post counts.Prince_Asuryan wrote:Just to be awkward. I feel that the post counts generally give a good indication to the new members of the forum who are reliable and experienced members of the boards, seen as OT doesn't effect it.Burning Sun wrote: Also, if you think we should keep them, speak up! I can only listen to people that tell me things.
True, ranks lead to spamming, but the post count is still a nice instrument for the newer members, as prince asuryan said.
Well, I'll probably fall below 100 posts if the older ones are removed from the equation (my most active time was during the storm of chaos, some time ago already)
[img]http://www.abload.de/img/afbeelding1b0f4.png[/img]
Nachri, Subcommander of the Vengeance of Vaul
11/15/8 (5 massacres), kills 227
As a 'newer member' can I just add my support for keeping the post count.
Even if all they do is give a rough 'n' ready guage of how much someone contributes, that's still worthwhile.
I'm sure we all learn fairly quickly who is worth paying attention to, but the post count is a useful 'ready reckoner'.
All that said, seeing as I've only 21 posts feel free to ignore me!
Tarrowhin
Luck is a meeting of preparedness and opportunity
- Ruerl Khan
- High Executioner
@Tarrowhin:
The quality of your input, not the quantity of your inputs, is what merits consideration. Thus while we do hear your argument, we also have to ignore a part of it, since its ironically based on your post count.
Lets make that perfectly clear: We do not judge a person on the number of posts they make, we judge a person by the content of his or her posts.
As for titles and such, they can still be handed out to active, and postivedly contributing, members of the community should we feel like it or should it be felt warranted, its not like custom titles are a rare thing either.
I love pushing around my small delicatedly painted dolls together with the rest of you.
